964 Forum 1989-1994
A 964 "Cup Chip" too good to be true?
Old 07-06-2005, 01:42 PM
agentpennypacker
agentpennypacker's Avatar
If anyone here can burn chips, we should get our hands on one and have some of us do before and after dynos with the RS or Cup chips... I'll participate for sure. The blanks only cost $7 USD or so.
Old 07-06-2005, 01:56 PM
JC in NY
JC in NY's Avatar
According to Cupcar's dino run, that is 258 hp at the wheels. Allowing for a 15% drivetrain loss, we are looking at 303 flywheel hp. Am I reading this right? If so, it confirms what I always suspected about Cup engines, they put out alot more horsepower than anyone is willing to admit. And those that have been further "blueprinted" to 11.3:1, well there's got to be at least 315 output there. Hello?
Old 07-06-2005, 02:17 PM
Geoffrey
Geoffrey's Avatar
I have done the back-to-back dyno runs with a stock C2 cup chip, a Euro RS chip, and a Euro Cup Chip. The part numbers of the brains were 964.618.124 (C2) and 964.618.124.00 (Cup Car) and the HP difference between the C2 and the Cup car was as I posted earlier. The RS and Cup cars produced effectively the same hp.
John,
You are reading the dyno results correctly...
Old 07-06-2005, 02:20 PM
C4Russ
C4Russ's Avatar
Default I have access to gear to burn chips
I have to ask though, is it ethical to do so? Is the data on these chips IP to another person who should be compensated?
Old 07-06-2005, 04:13 PM
Schuey
Schuey's Avatar
I'd check on the original chip, if there is no copyright law written on it, I'd assume it's free...
then again to be on the safe side, I'd re-up my PCA membership so I wouldn't feel too guilty...
Old 07-06-2005, 04:39 PM
agentpennypacker
I don't feel guilty here - Look at Porsche's profit margin on the Boxster WITHOUT a drysump systme (obviously to cut corners). Who's on board with me?
Old 07-06-2005, 05:46 PM
Eric Kessel
Eric Kessel's Avatar
I'd be more than happy to try one out in my 90C2 to see what it would do!
Will the RS chip work in an older DME?
Old 07-06-2005, 05:56 PM
Geoffrey
Geoffrey's Avatar
I have had chip compatibility issues between the 1990 brain and the 1992 brain.
Old 07-07-2005, 12:24 AM
Lorenfb
Lorenfb's Avatar
"I'd check on the original chip, if there is no copyright law written on it, I'd assume it's free.." - Schuey -
Not true!
The original Porsche DME chip microcode IS covered by copyright law and, as
such, all the basic elements of copyright infringement apply. It's not necessary
that copyright be posted on intellectual property to be protected.
So, all those performance chip suppliers are in violation of Porsche's copyright.
As an example, ask AMD what happened when they used Intel's math coprocessor
code in their 486 chip.
Old 07-07-2005, 10:25 AM
Schuey
Schuey's Avatar
Not true!
I think you forgot to add the LMAO underneath the posting...I was joking...
Old 07-07-2005, 04:50 PM
agentpennypacker
Loren is going to tell us that you can't get power from chips next...
Old 07-07-2005, 05:04 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
And for 96.4% of aftermarket chips he'd be right!
Old 07-07-2005, 05:24 PM
C4Russ
C4Russ's Avatar
Default Which 3.6% should be considered for chips?
I've just recevied Adrian's book and he is none too excited about chip mods bringing any benefit.
Which brand(s) actually provide a benefit to the stock engine?
Old 07-07-2005, 05:29 PM
garrett376
garrett376's Avatar
My thoughts on the matter - if you can run a higher octane, good quality fuel ( like race gas) , I would think that 96.4% of the chips out there would provide a noticeable benefit from an increased ignition timing advancement thanks to a different chip.
If you run on crappy pump gas (like 91 octane So Cal gas - that's the best we've got) and just tool around town then you'll likely get nothing from an upgraded chip but increased knocking/pinging/pinking.
Old 07-07-2005, 05:38 PM
Geoffrey
Geoffrey's Avatar
There is in fact benefit to be gained from improved ignition timing over stock C2. This is shown by the power differences between the C2 and the Cup Car or Euro RS chips. The C2 chip is programmed for lower octane fuel such as 91 octane where the Euro RS and Cup car are programmed for 98 RON or about 93 octane US measurement (R+M/2). I have not been able to improve on the Cup Car timing running 93 octane fuel and a blueprinted true 11.3:1 compression engine. In fact, an aftermarket chip (from europe) I tried had 3-4 degrees more timing than the Cup car and the plugs showed some signs of detonation. I do not know where the chip came from as it was in a brain from an imported Euro Cup car.
I have been able to get better air fuel ratios than the Cup car or C2 chips by programming chips, but have not seen any real HP gains from it. The 1990 C2 brain has a fuel quality swich that can add +3% (position 1) or +6% fuel (position 2) which does help a car that is running lean due to exhaust/cam changes.
If it were me, I would look for a Cup Car or Euro RS chip for my C2 provided you can run 93 or better octane fuel.
Quick Reply: A 964 "Cup Chip" too good to be true?
