Help Im melting !
Help Im melting !
I just finnished reading 1000 posts on the heating system and I still cant figure it out. I have hot air blowing from every vent including defrost and it wont stop when turned to blue dot and fan off. Last season I cleaned my servos (2) which seemed to work at the time. They were both stuck and I had only cold air. I tried disconnecting both arms today ,just as a temporary fix ,and that closes the valves which should give me only cold air again, but its still hot. I thought I understood the system but I guess I dont. Is there something else besides these two servos that I should check and why does closing these two servo rods not override the system and stop the heat? Maybe its the heat!!! 91 c2 Thanks for any help.
Technical Guru
