How much money did you spend?
How much money did you spend on your car this year, (upgrades, maintenance, and mechanical failures)? What do you forcast for next year $$$. What new upgrades do you have planned?
Here it is - annotated even!
2001 Porsche Expenses
A tiny fraction was recouped by selling the old parts.
High,
I lost count, but I know it was all worth it,lets see; carbon fibre/aluminum handbrake, shifter, and gauge surround, installed heat in the drivers seat, andial semi-lightweight flywheel w/a new clutch and sport chip,factory 22mm front and rear sway bars, 2 rear SO2's(17's),ummm, oh yeah a set of Bilstein shocks(already had the eibach springs,so that helped a little), a 30K mile service, and 4000 miles worth of gasoline. I think i,m finally done after 10 years of ownership, except for the gasoline expence of course.....
me wife
me wife
Purchased this car in October so $0 this year. Major service and new clutch due in Jan, plus suspension and wheels upgrade planned for next year - so projected expenditure next year must be at least £3500 or $5000. Hopefully I will need a top end rebuild soon as well - the 3.8L conversion in the UK works out at around £8500 all in...
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
My C4 got some upgrades this year, 2001 to the equivalent of about $US5,000. I have a service due and that will be another 1700CHF.
Failures in 2001 were limited to one water pump failure. Replacement from UK cost me 12 UK pounds plus shipping.
944 which I gave to my daughter set be back another $3,000 to get it onto the road.
Ciao,
Adrian
911C4
PS: Insurance and road taxes cost around 4600CHF per year for the 911 and 944.
Ciao,
Adrian
911C4
I try to keep good records, but everyting does not get logged. 2001 saw a full engine rebuild with 993 P&Cs from eBay ($540) included below. Also, 40 DE days (19 shared days for the wife and me, plus 2 more for me, solo). Hoping for similar track time next year. Also - one more possible iupgrade for next year - see new post...
2001 Expenses (Partial List)
March, 2001 engine rebuild 11300
March, 2001 engine work 500
March, 2001 HR coilovers 3000
March, 2001 tires 600
March, 2001 body work 170
April, 2001 mirrors 400
May, 2001 brakes 600
June, 2001 wheels 1050
June, 2001 hoosiers 850
August, 2001 service 1545
August, 2001 hoosiers 800
Sept, 2001 wires 300
Sept, 2001 wheels 900
Sept, 2001 markers, pedals 400
Oct, 2001 Used Sway Bars 200
total $22,615
Est 2002 Driving Expenses
Streeet Tires 800
Hoosiers 3000
Pagid 1600
Evo Ax School 900
DE Fee 4000
Engine Svc 1500
Seats 1500
Misc Repair 3000
DE Hotel 2600
Total $18,900
total $22,615
Streeet Tires 800
Hoosiers 3000
Pagid 1600
Evo Ax School 900
DE Fee 4000
Engine Svc 1500
Seats 1500
Misc Repair 3000
DE Hotel 2600
Total $18,900
My 92 C2 Coupe had about 41K miles at the beginning of the year and now has about 55K miles. I spent about $3500 on the car over this past year, and the breakdown is roughly as follows:
$1500 Routine maintenance, including replacing distributor belt
$1900 Street tires, extra set of 996 rims, track tires
$200 Mechanical failure- clutch roll pin came out, leaving me stranded. Of the $200, $120 was for a flat bed tow truck, so the whole incident was mainly an inconvenience. A buddy of mine pointed out that it was cheaper to fix the car than to maintain it.
So out of the $3500, $1700 was for maintenance and repairs, which comes out to $140 per month. Not bad for a daily driven 964.
Drew
Drew
I'm at $3850 for 2000, with the major expenses being:
-New clutch = $1210.
-Final debugging of the 993 engine installation (idle issues mainly) = $600.
-All fluids replaced, repair passenger door lock and other odds & ends at Andial = $573.00.
-Replace CV boots, repair oil leak = $308.
-Install new gas filler neck = $170.
-New right-rear tail-light assembly = $180.
-About $500 in miscellaneous trim items such as center console lights, center console spoiler switch housing (mounting tabs busted off of old one), relays/switches for the oil cooler system.
Don't want to think about the 1999-2000 numbers, which reflect the 993 engine/trans installation.
Next year should be a good one (fingers crossed). Car's all serviced, requiring only an oil change--no valve adjustment.
Since I bought my car in 1992, the lowest cost year has been 1993--the first year of ownership--at $842 (major service and rear brakes). The next cheapest year was 1997, at $1895.
Mods for next year? Installation of a converted 993 exhaust system, or more likely the GHL cat-header/heaters.
Hey Kevin ... how 'bout yourself? I know you did several interesting projects this year.
Bought my '93 C2 tip on October 30. Immediatley spent £1900 on new rear discs, pads & sensors, new front pads, new front wishbones, oil pipes from reservoir to oil cooler. Recently spent £60 on new battery (previous owner left me with a 45 Amphr tiddler!!) and £70 adjusting passenger door handle.
The car is super. Will spend £400 on a service in 2002, about £500 on a new rear taillight assembly and hopefully that will be it!!
Merry Xmas.
Merry Xmas.
Let's see...bought the car in May:
17" Boxster/996 Twist wheels - $950
Bridgestone tires - $600
Cup LWF/Clutch assembly - $1350
Bilstein shocks/H&R springs - $1200
16" 993 wheels (track) eBay - $600
1" Spacers for rear wheels - $120
Hoosiers - $800
PCNA Bra front/mirros eBay - $80
Aero Mirrors, used (GP White)- $300
RSA one-piece (MA Shaw) tail - $475
Bow plane spoiler (MA Shaw) - $275
Paintwork for above add-ons - $300
Brey Kraus strut brace - $200
BK harness brace - $300
BK fire extinguisher mount - $75
Sparco 4-point harness - $150
Interstate Battery - $75
Windshield wiper blades - $20
New rear window wiper arm - $90
-this thing broke for no reason!!-
17" Cup II wheels (for track)- $900
Kumhos ECSTA 700s for 17" - $600
**Recovered expense - SOLD**
-spacers/16"wheels/Hoosiers + $800
F/R Cup Swaybars 25.4mm/22mm - $600
Pagid Orange pads x 4sets - $600
Mintex C-Tech pads x 2sets - $230
Rotors, cross-drilled x 8 - $700
Fuel filler neck + new cap - $90
Fabspeed muffler/Euro Premuff- $800
K&N filter - $45
Airbox Modification - Free!
Used ZF limited slip diff. - $750
Misc. parts to install LSD - $100
Custom burned perf. chip - $400
Euro clear marker lenses - $120
Brake ducts, used - $50
Engine tray removal - Free!
Dual to single pulley conver.- $65
2 oil changes (Mobil One) - $150
Change trans. lube (Mobile 1)- $30
Sub/amp/spkr/CD deck upgrades- $900
6 DE events, one free - $830
Miles on car since purchase - @9K
Miles on Silverado since 964 - @9k, Hmmmm?
***On TRACK experience***......PRICELESS!!
2002 will see a dist. belt replacement, 60K service, rollcage/racing seat install...plus MANY more upgrades!
Thank God I'm a DIY'r...or this would cost me a fortune! But wait, it STILL costs a fortune!
Hoosiers - $800
K&N filter - $45
Anybody that spent this much money on a 911 should have been ready to run a bathtub full of water, climb in and un-zip a vein after seing that DP 935 go for $40,600.00. Here is a car that had it all. 570 HP, supension, brakes, looks, exclusivity, and to top it off, purist appeal! When somebody put a link to the car on ebay, the reaction was to immediatly criticize the car. But I guess if I had 40K in some non-turbo slug I'd be looking for a reason to criticize that car too.
Nobody criticized the car - they questioned the authenticity, and criticized the seller for not providing more details or responding to questions. With the reserve as low as it was, it was either some sort of kit, or an extremely good deal. It looks like it's gonna cost someone $40k to find out...
Originally posted by Carlos:
<STRONG>Anybody that spent this much money on a 911 should have been ready to run a bathtub full of water, climb in and un-zip a vein after seing that DP 935 go for $40,600.00. Here is a car that had it all. 570 HP, supension, brakes, looks, exclusivity, and to top it off, purist appeal! When somebody put a link to the car on ebay, the reaction was to immediatly criticize the car. But I guess if I had 40K in some non-turbo slug I'd be looking for a reason to criticize that car too.</STRONG>
Carlos, you always have a graceful way of putting words.
BTW, I am VERY proud of my "non-turbo" slug...and that's 50K I have invested to date.
I didn't follow the link, but I'm sure a TRUE DP935 would go for well over 40K.
Let's try to be a little less critical of people on this board...we're all here to have fun and fill each other with useful, sometimes useless, information.
