16" Boxster wheels on 964 ?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Yes Patrick the change in offset is going to matter. From the best of my knowledge, off the top of my head, the Boxster wheels are 40mm offset. This means they will be somewhat closer to your outer fender. If you are not lowered in any way then this will be a handling issue and looks issue. If you are lowered it may also create wheel rub problems. If you install these Boxster wheels you will in fact be increasing your wheel track, front and rear by one inch. This will affect your handling. Good or bad I cannot say. Depends what you use the C4 for,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
