Trickle Charger mains vs solar?
I am going to purchase a trickle charger for my 964....one that plugs into the cigar lighter socket. Do any of you have comments as to the best / most convenient charger....solar vs mains etc?
I have four racecars, I have bought Porsche Battery Maintainers for each. Although I cut off the lighter plug and use clips and go direct to the battery, this would be your best bet. Watch ebay or excellence and you'll find one at a reasonable price.
Ryan,
Depending on when and for how long you plan on using this thing, I'd probably advise against a "trickle charger" in favour of a proper "battery conditioner".
The difference is in the switching of the charge, in that a trickle charger continually charges the battery at a slow rate regardless of the state of the battery - potentially overcharging it if left connected for too long. The battery conditioner, on the other hand, will automatically switch off (at least stop charging) when the battery reaches full charge and switch back on again if/when the voltage drops.
Personally I use a Carcoon conditioner (see here) which is connected directly to the battery with the leads supplied and plugs in via an inline connector when needed. It can be left for weeks/months on end and keeps the battery in top condition.
Hope that helps.
Regards
Dave
Hope that helps.
Regards
Dave
Or you could look at an Optimate charger/conditioner, I paid £30 for mine at a show and use it on my car and bike. There is nil drain on the bike battery while it's stood in the garage, the Optimate cycles (!) the battery to keep it fully functional.
Barry
Barry
I bought a solar charger to keep a tractor battery up in a location where power was not available. I did not last a year before it quit working. There was no way to fix it, and it was quite expensive. The "chipped" battery maintainers are the way to go.
Last night I borrowed my father-in-laws trickle charger that he uses through the cigar ligher socket on his Morgan Aero 8.....woke up this morning to find that my battery was completely flat! slightly concerning! I have now put the battery on 'proper' charge.
After doing a web search I have come accross this... http://www.hamiltonclassic.co.uk/Pro...ryCareCTEK.htm , anyone got/ use one?
Cheers,
Ryan
Cheers,
Ryan
The Porsche conditioner works great. I have a 36 amp battery in my car... conditioner needed after each outing
On the other hand, my sister in law has a VW solar powered conditioner and it works great too. Through the cigar lighter.
Post your findings, I'd be interested.
Sorry if this is a stupid question/comment, but i was under the impression that not all 964's had the lighter socket permanently live? My LHD car does so the trickle charger via the socket works fine and keeps the battery optimal, do the UK RHD cars have the live socket and therefore would a charger work? Just a thought.
Cheers.
Cheers.
