Oil Level Sender Unit - Leaking?
Is this possible? I've got a lot of oil below this thing, assuming it's the 'thing' at the front of the rear wheel on the drivers side (RHD car)
Thanks in advance!
Piers
1990 C4 Coupe
Thanks in advance!
Piers
1990 C4 Coupe
I have a similar leak on my C4Cab. I had my car
serviced at the local P-dealer. The leak was small,a few drops per day but when I got my Pcar
back it leaked much more. I had the metal gasket
changed on the oil plug but it still leaks. I can't determine if the oil leak is from the plug or the thermostat housing. <img src="confused.gif" border="0">
Specialist
First thing to try is to tighten the hoe clamps in that area. Over the years the hoses are compressed, and need snugging. That solved my problem in that area.
