Check Engine Light on/off/on
1991 C2, runs perfectly, oil pressure excellent, oil temp nice and low, oil level perfect, all belts fine. Check engine light came on during a 1000 mile trip, went off, came back on again. I will bring it in to the shop Monday, just curious if there was something I could check out in the meantime.
Thanks!
Thanks!
You can "pull the codes" by your self - if you search on here, there is a description of a method to do it using just the gas pedal pressed in a certain way with the ignition on (not the engine) - I can't remember off-hand or I'd give you better information! But you can see what code is stored by the DME computer by doing this - then you'll have an idea of what's wrong.
Originally Posted by Gary R.
THANK YOU!
That is excellent, he did do a great job. I have code 1232, which is Knock Sensor II. It even knew that it was an intermittant problem!
What exactly does that code mean? I never had that happen.
thanks! Michael
Originally Posted by msrc2
Gary, When did this start?....? on the drive home or after you got there??.
thanks! Michael
thanks! Michael
I gave her the clay bar treatment today and two coats of Zaino, paint looks beautiful. Take a peek -
