964 Forum 1989-1994
Gremlin noises???
Old Sep 20, 2002 | 12:03 PM
Oilslick964's Avatar
Oilslick964
Post Gremlin noises???
When it is cool outside, or when I just start my car and drive it, everything is fine. When it gets warmer, there is a noise that I just can't figure out. Sounds like the rear brakes (mostly left side, I think) are grinding. Only thing is, the noise does not change when I press the brakes. It stops when the car stops. It starts and continues any time the car is rolling, whether I'm on the brakes or not. Pads were just changed a few months ago. I do not hear any noise at all when car is cold. Any ideas???
Old Sep 20, 2002 | 12:27 PM
Andy Roe's Avatar
Andy Roe
Post
Is it a low or high pitch sound? I occaisionally get a faint high pitch noise when my car is hot - generally hear it when in slow moving trafic in second or third gear. I too wondered if it was the brakes, but also just had them changed!
Is your noise similar?
Andy
Old Sep 20, 2002 | 12:31 PM
Oilslick964
Post
It's pretty high pitched. Sounds like metal on metal.
Old Sep 20, 2002 | 12:32 PM
Andy Roe's Avatar
Andy Roe
Post
I am wondering if it is the alternator bearings?
Old Sep 20, 2002 | 12:57 PM
Oilslick964
Post
would that stop when the car stops (at a stop light or something)? It is definately related to the wheels rolling, in my case.
Old Sep 20, 2002 | 01:04 PM
Andy Roe's Avatar
Andy Roe
Post
Funnily enough mine too stops when the car is not moving! I'm having the engine & gearbox pulled next month for a flywheel & clutch - I'll get my mechanic to check the gearbox/wheel bearings.
Does it make the noise if you are coasting in neutral? That would rule out the wheel bearings and point towards the gearbox perhaps?
Andy
Old Sep 20, 2002 | 01:16 PM
Oilslick964
Post
No, t still does it whether I'm coasting or under power. I'm perplexed. Please post if you figure anything out. Any other suggestions???
Old Sep 21, 2002 | 07:50 PM
Oilslick964
Post
Got it! It's definately related to the parking brake. Don't know exactly what the problem is, but I can manipulate the p-brake and the noise will vary. Anyone ever had any experience with this???
