Power Steering fluid rehash
Jarhead
I posted a question as to what type of fluid to use in our power steering systems a few months ago, and after re-reading that thread I'm still very confused. The owner's manual says Dexron I. Adrian's book says Dexron II or Dexron III. I'm assuming these two suggestions of Adrian's are compatible with the suggestion by the manual. However, these are all automatic transmission fluids, not power steering fluids, correct? Today I purchased some Valvoline SynPower power steering fluid but I'm not putting anything in until I'm confident that I'm not going to destroy my system. Looking at Adrian's book again it seems that synthetic automatic transmission fluids are a very bad idea. Can someone explain the difference between auto tranny fluid and power steering fluid and direct me toward which to use, please. Thank you. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Brian
Brian
Jarhead
Alright sounds like a plan. The bottle of "power steering fluid" I bought says Dexron nowhere on it, so it's back to the auto parts store for some ATF that does. Thanks for the tip, Indy.
Brian
Brian
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
The Porsche power steering system of the 964 uses the same specification oil (read the owners manual) as Automatic transmissions of the time.
This oil is mineral based.
Ciao,
Adrian.
Ciao,
Adrian.
Jarhead
I did my homework, but it still wasn't clear to me what was going on. That's why I'm so glad I have this place.
Brian
