Final results from 9M surgery....
Indeed, thank goodness, and it's now shod with 17's fron the autojumble today. No 'G' pipe, but nearly bought a 'cup' pipe, will take advice tomorrow. Off to the kitchen now for a 4 hour stint. Cheers. Raymond
Location: WhippetWorld, .........is it really only this many
1 Post
Originally Posted by DaveK
Forget the intake. After your "look how quickly I can pull away from traffic lights" demo I suggest the next thing you spend your money on is a tiptronic conversion.
Tricky things those clutches eh?
Originally Posted by tonytaylor
What happened?
1 Post
To be fair with that amount of torque evrywhere in the rev range and a LWF you're going to have problems with fast take offs.
2 pieces of advice FWIW
1) Best way for a quick standing start is to dump the clutch at ,say, 3000 revs (it's about 3500 in mine) and then floor the throttle. If you slip the clutch it just burns out and continues to slip. With that amount of torque/power the car won't bog down. If you have a G-tech it will confirm it's a fast way to 60mph and you should easily dip under 5 secs.
2) Investigate better clutch components
