Dyno Results for The Turtle
Originally Posted by targa72e
I would agree that the loss in hp is probably a result of the air fuel mixture being to lean. If you add parts that allow the engine to flow more air but do not change the fueling you will not make more HP unless the car was too rich to begin with. A/F mixture at WOT should be in the 12.5-13.0 range 14.0-1 is too lean.
john
john
it is not just the A/F that makes the power. If you are too lean then you are more likely to get detination, which pulls timing which has a big effect on power.
So someone in Europe with high octane gas might see a good power gain whit mod X, while the customer in California having to run on 91 octane crap might loose power with same part. The key is that if you make big changes to the engine you cant expect the stock programing to be optimized, you need to tune to the new configuration.
john
john
