964 Forum 1989-1994
Slippery question
Old Mar 14, 2002 | 12:46 PM
Arthur.'s Avatar
Arthur.
Question Slippery question
In one of the other threads, Adrian explained that there's about 2 litres of oil in the engine when you start it. I was wondering, given the fact there's a thermostat in the system that opens up at certain temperature and allowing the oil to start flowing around and through the oil cooler, how much oil is actually going around through the engine before the thermostat opens up. If it is such that the remaining 10 litres are then sharing the hot 2 litres, it would explain why the oil temperature drops quickly once the thermostat opens.
With water-cooled cars, the amount of cooling fluid is limited to have it heating up quicker, and once the thermostat opens, the fluid is allowed to flow through the entire system including the radiator.
Just wondering how this works for an oil-cooled engine.
Old Mar 14, 2002 | 03:03 PM
Kevin's Avatar
Kevin
Post
Arthur;
All the oil in the oil tank (dry sump) is used for lubrication and cooling (piston squiters). The engine on startup instantly starts to scavage the oil out of the block. The scavaged oil goes to the oil tank. Basically you have the full capacity of the system right at startup, minus the oil capacity that is in the oil lines that go to the oil cooler, and oil cooler.
Old Mar 15, 2002 | 08:01 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Dear Arthur,
You have about 8 litres available in the engine very shortly after it starts to turn and then fire. Once the oil cooler is opened a huge amount of heat is released and quickly especially if moving forward,
Ciao,
Adrian
911C4
