I used epoxy to glue it back together, I used epoxy to put atleast a dozen things together, mostly plastic. No problems at all, holds better then new.
The adjusting tabs are very delicate. I suggest they are broken when an attempt is made to remove the reflector. When I rebuilt my fog lights (replaced the glass lens only https://rennlist.com/forums/964-foru...ht-repair.html) I quickly backed off my disassembly until I figured how to twist off the reflector without placing any pressure on the tab.
