brake caliper,time for rebuild??
Looking for a little help guys, starting to put on new rotors and noticed that it took a little more force than I thought it would to push the pistons back into the caliper. How hard should this be?
How hard to re-build the calipers if need be.
Thanks,
Drew
89 C4
Thanks,
Drew
89 C4
I usually need to use a pipe wrench (channel-lock) to retract the pistons - so it does take a decent amount of force. If you end up with brake pads where one pad is worn paper thin, and the other pad is not worn at all; or, when you have brake fluid leaking - that's where you determine it's time for a rebuild.
Originally Posted by bhensarl
Another thing that can work well to retract the pistons is a C-clamp with a block of wood, or the old brake pad to push the pistons back in.
Brian
Brian
There is less of a chance to ruin the seals and (I feel) you can control things a little more. I am assuming that the calipers can be pushed right in on a Porsche... Some other makes require a special caliper compression tool that twists the piston as it pushes it back in the caliper. A real PITA!
Super Duper Moderator
Brian
Brian
C-clamp worked well.
Marc
Jarhead
I actually got those two tricks changing out the brakes on a buddy's 4Runner. It's amazing how much easier a job can be when the car starts with a foot of ground clearance instead of four inches! But the ease of maintenance is more than offset by the fact that it's not any fun to go around corners!
Brian
Brian
I wouldn't bother pulling the cap off the brake fluid reservoir unless your car has been upgraded to the sealed cap style that was introduced on later 993s.
All our 964s came with vented reservoirs - the tube running from the reservoir toward the wheel well which you must clamp off when you try to apply a pressure bleeder like Motive to the reservoir.
Technical Guru
Well, empirical results trump theory.
I've not been motivated to remove the brake fluid reservoir cap because I've not had any trouble patiently retracting the caliper pistons with Channel Loc pliers, and I managed to get 2 hands in place to install the clutch slave cylinder. I'll keep the option in mind though.
