Recall WM02?
Technical Guru
For a MY1990 I found the following (the numbers probably don't match up with PCNA's). The fuel recall is for MY89 3.2 (not the 964) but I'll include it anyway.
1. Summary:
LUGGAGE IN THE LUGGAGE COMPARTMENT AND OR PLASTIC TRIM SURROUNDING THE SAFETY LATCH MAY PREVENT THE LATCH ON THE FRONT HOOD FROM PROPERLY LOCKING.
Consequence:
LATCH FAILURE COULD CAUSE HOOD TO OPEN AND OBSTRUCT THEDRIVER'S FRONT VIEW WHICH COULD RESULT IN AN ACCIDENT.
Remedy:
REPLACE PLASTIC TRIM PIECE AND INSTALL A BRACKET BEHIND THE SAFETY LATCH TO PREVENT INTERFERENCE.
2. Summary:
THE BALL SOCKETS ON THE CRUISE CONTROL LINKAGE CAN BREAK, ALLOWING THE CRUISE CONTROL LINKAGE TO BECOME DETACHED ON ONE END AND JAM ON NEARBY COMPONENTS, WHICH COULD IMPAIR THROTTLE PLATE OPERATION.
Consequence:
IMPAIRED THROTTLE PLATE OPERATION COULD PREVENT THEENGINE FROM RETURNING TO IDLE, RESULTING IN UNWANTED ENGINE SPEED AND POSSIBLEVEHICLE ACCIDENT.
Remedy:
REPLACE THE CURRENT PLASTIC BALL SOCKETS WITH A NEW LINKAGE USING STEEL BALL SOCKETS, AND LUBRICATE THE CRUISE CONTROL RELAY LEVER. OWNERS ARE ADVISED NOT TO USE THE CRUISE CONTROL UNTIL THE MODIFICATION IS INSTALLED
3. Summary:
AFTER THE ENGINE HAS BEEN TURNED OFF, THE REAR HEATER WILL AUTOMATICALLY OPERATE IN ORDER TO DISSIPATE HEAT IN THE ENGINE HEATING SYSTEM. DURING THIS OPERATION, THE RESISTOR FOR THE REAR HEATER BLOWER CAN BECOME OVERLOADED DUE TO A BINDING OR SEIZED REAR HEATER BLOWER.
Consequence:
THE OVERLOADED RESISTOR CAN CREATE HEAT SUFFICIENT TOIGNITE THE PLASTIC AIR PIPE TO WHICH IT IS CONNECTED, RESULTING IN AN ENGINECOMPARTMENT FIRE.
Remedy:
PORSCHE DEALERS WILL INSTALL A NEW RESISTOR CONTAINING A CIRCUIT BREAKER.
4. Summary:
A PART OF THE STEERING COLUMN UPPER UNIVERSAL JOINT CRACKED DURING THE MANUFACTURING PROCESS.
Consequence:
THIS CONDITION COULD RESULT IN NOISE AND FREE PLAY IN THE STEERING SYSTEM AND IF LEFT UNCORRECTED, WILL RESULT IN LOSS OF STEERING CONTROL.
Remedy:
DEALERS WILL INSPECT THE UNIVERSAL JOINT FOR CRACKS AND WILL REPLACE CRACKED JOINTS WITH NEW PARTS.
5 - DOESN'T APPLY
Summary:
DUE TO ROUTING OF FUEL LINE FROM THE FUEL TANK TO REAR FUEL PUMP, THE FUEL LINE MAY BE DAMAGED UNDER CERTAIN DRIVING CONDITIONS. ON FULL TRAVEL OF LEFT REAR SUSPENSION (JOUNCE), THE BRACKET FOR THE BRAKE PAD WEAR INDICATOR WIRE ON LEFT REAR CONTROL ARM COULD CONTACT AND DAMAGE FUEL LINE.
Consequence:
A DAMAGED FUEL LINE MAY RESULT IN A FUEL LEAK WHICH MAYIGNITE, RESULTING IN A FIRE.
Remedy:
REPLACE DAMAGED FUEL LINE: IN ADDITION ALL FUEL LINES WILL BE REROUTED SO THAT THE BRAKE PAD WEAR INDICATOR WIRE BRACKET CANNOT CONTACT FUEL LINE.
1. Summary:
Consequence:
Remedy:
2. Summary:
Consequence:
Remedy:
3. Summary:
Consequence:
Remedy:
4. Summary:
Consequence:
Remedy:
5 - DOESN'T APPLY
Summary:
Consequence:
Remedy:
I just got off the phone with a buddy who works at HBL in Vienna, VA. He said that he talked with his service manager about the recalls, WM02, WM03 & WM04. He said (as was stated by Jason) that the WM02 recall had to do with the fuel level sending unit. He said that it was not a saftey issue but an "annoyance" issue. Porsche said that mine had already been done but I have my doubts... I'm taking it there next week for them to take a look.
In regard to WM03 & WM04, the service manager said that they were "European" (I'm assuming ROW) recalls that did not pertain to me or my car... And not to worry about it. No other info on those recalls.
I'd feel better about this if we could get an independent confirmation about these recalls. I've called all the stores in my area. Can someone else snoop around and post what they find out? Perhaps Adrian could chime in with his wisdom and let us know the straight skinny.
