Replacing rear speakers
Hi all,
I am going to replace the speakers in the rear parcel shelf, can anyone tell me what size speakers will fit?
And is the rear shelf easy to remove?
Thanks in advance
Ian
1990 C4
Thanks in advance
Ian
1990 C4
Ian,
I think they are 6x4" speakers. You may have problems getting them with grills. I beleive the parcel shelf just un-screws - screws visible when rear seats folded forward.
Check out the archives. This has probably been covered before.
Andy
Andy
Yes, save those 4"x6" grills:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=4&t=002080" target="_blank">Source for 4"x6" Speaker Grill?</a>
BTW, the rear speaker grills aren't even real Blaupunkt units. They have a 944 part number on them, and are shown in PET. So, I suppose you can get a new set from the dealer, if you have the need.
Ian,
Assuming the 6" x 4" grilles are the same as on my 993, be careful. They are a "snap" fit and crack very easily on removal. In our hot climate mine certainly did.
I've read posts of replacing them with larger speakers such as standard 6" x 9". That requires cutting the shelf and to look out for shallow mounting depth.
Enjoy <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Nol
Nol
I installed a pair of Boston Acoustics 6x4s in my C4 a couple of years back. They're surface mounted and therefore easy to install.
I've never thought they sound all that good, though, and in retrospect, I should have spent the money on some better components for the front.
On Saturday I installed a hinged boot floor on which to mount an amp and crossover. Hinged so I can get to the spare wheel and battery etc. I tapped threads in the chassis rails so I could bolt on the hinges.
Next step is to get the cables routed through the bulkhead which is harder than you might expect.
I've now given up on saving the driver's side passenger footwell and am resigned to filling it with a GRP bass enclosure.
If anybody has done this kind of thing I'd be interested to hear their experiences...
Roly
Roly
Thanks for the replys, has anyone installed larger speakers than the existing ones? Can i not fit 6 x 9's in??? (I havent actually looked yet,went to get the car out of the garage yesterday to find flt battery!!and as my drive is uphill it will have to wait til next weekend now )
