964 Forum 1989-1994
Power Windows
Old Oct 3, 2003 | 05:56 PM
Phil Raby's Avatar
Phil Raby
Originally posted by Greg_L
I had exactly the same problem Phil, i'm afraid my mechanic friend noticed it while he had the car and repaired it. He said he took the interior panel off and there were not enough clips on the window ??
Sorry for perhaps the most vague post ever on this forum
Cheers,
Greg
Thanks Greg. I'll pop down the OPC and order some more clips
Old Oct 4, 2003 | 04:29 AM
Randall G.'s Avatar
Randall G.
Originally posted by robmug
...and how does a worn regulator cause a rattle? (I ask because I have a door rattle too...and I've not been able to trace the source)
I presume because the rollers have worn, allowing the window to rattle about in the track.
On Arjan's "Very Few 964s in California" thread, I made a few posts about replacing my regulator. The rattle with the window not-fully-up is now gone (not that the window regulator is the only thing that might cause a window rattle). Interestingly, I found no (obviously) broken rollers. So, I guess the rollers just wore out. Besides no longer rattling, the window hasn't stuck fully-up since replacing, and operates nice and smoothly.
Arjan has been encouraging me to sell my old regulator on e-bay. Say, at 50% of list price. A real steal.
Old Oct 4, 2003 | 04:37 AM
Randall G.'s Avatar
Randall G.
Originally posted by johnfm
Whats the diff between the regulaotr and the motor? Is the regulator the thing the window sits in, connected by that big part of a cog which converts the rotational movement from the motor into the up & down of the window??
I think I need to replace the motor in my drivers side. Is this a really involved R&R - I have had the door panels off for a bbit of a look and cannot see how I will get that motor out???
John,
Here's a picture of my new regulator as it was being installed. Of course, the motor turns gears attached to the regulator.
Old Oct 4, 2003 | 04:45 AM
Phil Raby's Avatar
Phil Raby
Note to self: Don't buy any regulators from e-bay
Old Oct 6, 2003 | 11:14 AM
johnfm's Avatar
johnfm
Thanks for the pic Randall - looks like a bit of a hassle just to remove & replce the motor - seeing as all else is ok.
Old Oct 13, 2003 | 09:47 AM
Phil Raby's Avatar
Phil Raby
Ok, I fixed my rattle. When the window was right up, there was some 'slack' in the regulator which meant that the jockey wheel at the rear was able to wobble about, leading to the rattle. All I had to do was loosen the Allen bolt holding the rear end of the runner and move the runner up slightly, thus eliminating the rattle. Easy!
Cheers
Old Oct 13, 2003 | 09:49 AM
John Boggiano's Avatar
John Boggiano
Lifetime Member
I'm glad you fixed your rattle, Phil.
Now be a good boy and climb back into your cot.
Old Oct 13, 2003 | 09:50 AM
Phil Raby's Avatar
Phil Raby
Now I see there's a dummy I have to sort out...
Old Oct 13, 2003 | 10:14 AM
johnfm's Avatar
johnfm
Phil
is your 1997 ****** ******* a Nissan Skyline??
Old Oct 13, 2003 | 10:19 AM
Phil Raby's Avatar
Phil Raby
Phil
I wish!
Old Oct 13, 2003 | 12:19 PM
johnfm's Avatar
johnfm
You mean its worse??
Maybe its a
1997 Toyota something.....
Old Oct 13, 2003 | 12:21 PM
Phil Raby's Avatar
Phil Raby
Maybe its a
Can we just change the subject? Now, about my windows...
Old Oct 13, 2003 | 12:49 PM
johnfm's Avatar
johnfm
1997 Datsun .........
1997 Holden .......
Old Oct 13, 2003 | 03:04 PM
John Boggiano
Lifetime Member
Well I happen to know this embrassing fact...
Phil's other car is actually a Nnnnnnnnnn owwwww uuufffff aarrrghhhh oooofffff ^&%^&%£&%%&! Somebody get him off me!
Old Oct 13, 2003 | 03:25 PM
Ruairidh's Avatar
Ruairidh
Super Guru
Didn't we cover Phil's little secret in another thread not so long ago?
