Engine Fan Bypass
Engine Fan Bypass
Just had TPC Supercharger fitted and the fan in the engine bay can no longer be sited there. Problem is the fans at the front of the car do not work any longer. I read that Bill Gregory fitted some electronics to fool the system into thinking it was still there, do I need this as well. If so does anyone know where I can get the resistors from ? I've tracking them down in the UK and not having much luck.
If you can get ahold of an electronics parts distributor, of which I'm sure there's got to be one available in the UK??
Then I'm sure Bill could guide you with the correct color codes/tolerance for the resistors needed.
I, for one, have not performed this mod.
...probably will wait until I complete my 993 exhaust conversion to do so as I understand I'm going to have to revamp the whole heater setup. <img border="0" title="" alt="[Eek!]" src="eek.gif" />
