Rocker sill trim cover strip replacement
Super Duper Moderator
Hi,
I'm working at replacing just the rocker sill trim cover strips (#5 & #6, below). I've looked at prior threads like https://rennlist.com/forums/964-forum/167292-rocker-trim-removal-just-pull.html
but I'm not sure if I have to remove the whole trims for door sills (#1 & #2, below) to do this or can I just pull the little rubber seal out and poke the new ones in (they shrunk, as they usually do).
Thanks.....Marc
Thanks.....Marc
Professor of Pending Projects
I have to do the same but in my case I will remove the whole thing to repaint the bottom part that is black.... I know I will loose a few clips along the way...
Did you buy the rubber strip at the Porsche dealer or at a body shop supplies place???
What, no replies yet?
I did this job a couple of years ago. I did completely remove the covers. They just pull off after removing all the under screws/bolts. Careful, as you can damage the fastners (3 and 7). I just used some epoxy weld stuff to fix the broken fastners. Anyway, with the sills off replacing the rubber trim strips is easy work. With them off, you might check with a local paint shop about the cost of repainting them. It will probably be less money than you think.
Good luck,
John
Good luck,
John
Originally Posted by Thomas Owen
I just did this last week. Got the rubber and new clips from the dealer - very inexpensive. Everything cleaned up and snapped back in place like new.
Good luck -
Good luck -
33.95 for each long section (#5 in the parts photo) - 965.559.295.00.01C / 965.559.296.00.01C
22.30 for each short section (#6 in the parts photo) - 965.559.293.00.01C / 965.559.294.00.01C
Mine has the wide body that explains the 965 number...
For 113.00 I wonder if this rubber strip is available at a body parts shop as a generic rubber trim
Clips: (#3) 999.591.991.40 - 2.93 each
(#4) 999.591.990.00 - 5.36 each
Burgled
Buy 3 long sections and cut 4 short ones from the extra and then sell 2 of them Save $9 and get an extra $44 You almost could turn a profit.
Looks like it would be a generic filler strip to me.
There are a bunch of little notches artfully placed along the strips that mate to little projections in the grooves of the sill and the shark fin, designed to keep 'em in place. A generic one might work, but I suspect it'd shrink and become displaced even faster than the Porsche ones. Last August the strips were $26CDN for the long and $14 for the shark's fin one. Fun with Porsche pricing!
IIRC it was $21 for long bits and $11 for short bits (2 of each).
Marc
Thanks.....Marc
Originally Posted by Marc Shaw
... It sounds like I won't be able to replace the little rubber strips without removing the whole sill trim pieces so I will need to order some little clips to replace the ones that I will (most likely) break in the process.
Originally Posted by DarrylH
make sure you find all of them or you'll become an epoxy expert.
Marc
How many clips are there?? ...
From memory (not to be completely trusted) I think there are 2 of the threaded clips on each panel =8 (I ordered 4) and 6 plastic pop-ins per side (both panels) =12 (I ordered 6 but had to go back and get a couple more, my bad) The female receptacles for the pop-ins also might not hold the male part tightly enough, so I'd get a few of them as well (you might not need 'em, but they're 17 cents each)
I guess I should just crawl under the car tonight and look but I'd like to be sure to get all the parts ahead of time as I have to order them from the US then wait 2 weeks to get them.....can't just pop out to the local dealer.
Marc
OK, here goes (I hope)
There are 2 #4 plastic-metal combination threaded clips on each shark fin, and at least one, at the front, on the sill. There MAY be 2 on the sill, sorry, not sure. John Miles's site says there are. Part number for #4 is ?999-591-916-40 as far as I can tell from the invoice, with nuts #15, part number 999-049-022-40. If you get all the nuts off before removal, they'll be reusable. But they're cheap. I broke a few. YMMV.
The pop-in all-plastic clips appear to be #3, part number ?999-507-373-00 - there are several along the length of the sills (and they're the ones that break easily) mated into female receptacles part number 999-702-160-40
Sorry to be vague, but the invoice just calls them all "clips" so I can't tell which part number refers to which number in the figure. I know the numbers are right, just not sure which number refers to the threaded and which to the pop-in. #16 is a metal clip for screw #18, reusable, which holds the bottom edge of the sill and shark fin together.
Unfortunately, it's hard to see what's what until you start taking the darn thing apart - all the plastic pop-ins are hidden behind the sills. I'd start by removing the shark fin on the LHS and work my way forward, remembering to remove the little access door behind the front wheel so you don't break the front threaded clip. Then you'll know what you're dealing with for the RHS where access is worse due to the oil lines and t'stat.
