Bosch Injectors
Hi All,
I've been trying to get some information on Bosch Injectors and their flow. If anyone has any flow info for these injectors, I would appreciate it. I've tried contacting Bosch with no luck.
Bosch Part #'s
0280-150-731 (stock 964)
0280-150-756
0280-155-010
0280-150-803
0280-150-945
GP
Bosch Part #'s
0280-150-756
0280-155-010
0280-150-803
0280-150-945
GP
Hi again,
The 731 flow is 20lbs@45psi, the 993 786 is 23lbs @45psi .Maybe you can check out the Audi 5 cyl S2 turbo.They use 0280 150 932,737 .Both are 16 ohm
with 30lbs @45psi.
with 30lbs @45psi.
