964 Forum 1989-1994
TWIN SPARK
Old Dec 14, 2017 | 10:56 AM
  #31
Turbohead's Avatar
Turbohead
Originally Posted by Porschenut_Lee
Significantly lower compression ratios on the turbo motors, less of a chance for detonation after ignition.
But compression pressure rise significantly on boost .
Old Dec 14, 2017 | 11:56 AM
  #32
JasonAndreas's Avatar
JasonAndreas
Technical Guru
I thought I read somewhere that for their street engines the trade off was that the additional surface area and mass for cooling the head was more important than any additional timing they could run? Porsche motorsports did twin-plug the M64/82 used in the MY98-99 993 GT2 EVO but they also had to use Secan intercoolers to reduce the intake temperature.
Old Dec 14, 2017 | 01:10 PM
  #33
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Originally Posted by Turbohead
Yes but production Turbos 930,965,993 TT all were single plug design. Why ?
Elliot
Street engines run .8 bar; race engines run 1.4 to 1.8 bar is one reason as well as cost.
Old Dec 14, 2017 | 01:17 PM
  #34
Raceboy's Avatar
Raceboy
Originally Posted by JasonAndreas
I thought I read somewhere that for their street engines the trade off was that the additional surface area and mass for cooling the head was more important than any additional timing they could run? .
With twin plugs you actually need to run less timing, meaning MBT moves closer to TDC. That is because mixture burns faster (having ignited simultaneosly from both sides of the combustion chamber).
Old Dec 16, 2017 | 01:01 PM
  #35
Lorenfb's Avatar
Lorenfb
Originally Posted by Bill Wagner
Cupcar:
I would have to question what you call "folklore". If I understand the reason the twin spark was used it was to allow a higher compression ratio with the car, hence more horsepower. The twin spark doesn't create the extra horse power...I suppose you could say it makes it possible though. Without the twin spark the car will suffer from pre-detonation.
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> Bill Wagner
Most need to re-read what was written over 15 years ago to get the simple answer!
Read under "Detonation" here: http://www.systemsc.com/problems.htm
