Ajustable
Ajustable
I am considering adding an adjustable rear swaybar to my RSA. I have done a small amount of research, and have found only bars that have 3 or 4 holes to attach the droplinks. I have not seen a bar that has a sliding clamp, like the AJUSA bar I put on my SC. That bar is very easy to adjust, even at the track -- just loosen the clamp nuts, tap the slider as far as you want to move it, tighten it up again, and you're on your way. I think the slider is a very common deaign, but I have not seen one for the 964.
Is anyone aware of such a bar?
Strabo
Strabo
Technical Specialist
Lifetime Member
Lifetime Member
Strabo,
I had that type installed on my SC - know what you mean. And no, haven't seen that in any of the available adjustable 964 bars. My only suggestion would be to go larger rather than smaller, ie, 21 or 22mm as opposed to 18mm.
Also, I've had the "slider" type on my SC...I like the holes better, it eliminates the "guesswork" associated with, "how much do I adjust"??
To play around with different adjustments, just move it up or down a hole, not much to commit to memory there!
I'm sure that you will find yourself using the 2nd or 3rd hole out of a four hole 22mm bar...probably the "looser" adjustment if you're keeping your factory front bar.
