Air Conditioning
Guest
Posts: n/a
Air Conditioning
Dear Sir(s),
Can you please advise what is the model for
the compressor used in a 964 and is it possible
to renew rather than replace one? The one in
my car is leaking badly and need possible replacement.
BR,
<img border="0" title="" alt="[Frown]" src="frown.gif" />
BR,
I have one out of my 93 RS America if you're interested. Check my ad for the part numbers.
<a href="http://mall.rennlist.com/scripts/featured/ads.cgi?db=parts&website=&session_key=&search_and_display_db_button=on&r esults_format=long&db_id=1836&query=retrieval" target="_blank">Renlist Ad # 1836</a>
Felix:
For a '92 and older 964:
-Repair kit magnetic clutch, 930-126-904-00.
-Repair kit connection-suct.+press.tub, 964-126-902-00. I presume this is for the seals, but you should verify with the dealer prior to purchasing.
For a '93 and newer 964:
-Repair kit magnetic clutch, 930-126-904-01.
-Repair kit connection-suct.+press.tub, 964-126-902-01. Again, I presume this is for the seals, but you should verify with the dealer prior to purchasing.
Good luck!
Good luck!
Guest
Posts: n/a
Dear David,
Thanks for your help. I'll check with the local
dealer to obtain the parts for rebuilding.
Hi Mark,
Yes I am going to both get a second hand compressor (if possible) and rebuild the compressor as well. Please advise how I can contact you. My phone # is 91025091.
BR,
Felix.
Hi Mark,
BR,
Felix.
