thanks Jeff Curtis - I conquered the tranny filler plug!
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Tonight I tackled the tranny plug from *%$$. And I won!!
Using Jeff's advice, I used my trusty el-cheapo grinder from Home Depot and ground a slot in the filler plug, then used a cold chisel and a hammer and beat the heck out of the thing. After almost giving up for the night due to lack of strength (ate Burger King today and felt sluggish ever since
) I gave it about 10 more smacks and it started to turn! Excellent!
So, thanks Jeff - your suggestion saved me from breaking out the welder and making a mess, which was my next step! Thanks buddy!
Yaaahh!! Now you can hold the new one next to the old one and say........See what happens when you F@$% WITH ME!!! Then beat the living crap out of the old one with the 10 pound sledge, for giving everybody a hard time. AHHH, feels good don't it?
Duncan
Duncan
Super Duper Moderator
Oh yeah - sometimes you have to show these inanimate objects who's boss....even if it just for your own satisfaction!
Marc
![order](https://rennlist.com/forums/graemlins/order.gif)
Marc
Springer it's not how the oil looked, but the piece of mind! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The oil actually didn't look that bad!!! I was expecting tar to come out of the case! There was a significant amount of "fuzz" on the magnetic drain plug, but the oil still had a slight clear/transparent element to it. It was dirty - not totally clear, but not as bad as some tranny cases I've seen and due to the fuzz, I was glad to change it...
The front differential on the other hand must have just been changed - or it's not hooked up to the driveshaft!!! The oil was perfectly clear! But there was some fuzz on the plug of that one, too.
Now I can rest easy knowing all fluids are new!
A little fuzz is normal, due to break in, and wear. It's pieces of bronze and metal bits you need to look out for. When I drain my fluids, periodically I'll use a paint strainer to check for chunks. Whatever can pass through that, I don't typically worry about.
Duncan
Duncan
Good to hear you got it figured out Garrett...as you may have surmised, I've "been there, done that...HATED IT!!" ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
As a good rule of thumb, I always tell people to make sure the FILL plug comes out prior to draining the trans. - wonder how I figured THAT out??
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
