964 Forum 1989-1994
300HP Everyday?
Old Jan 25, 2005 | 02:47 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The 964 was really clean for its time and there is a LOT of wiggle room to pass emissions, the pollution regulations at the time were;
Federal
Code:
          Pollutant                  Standard
             HC                      0.41 g/mi
             CO                      3.4  g/mi
             NOx                     1.0  g/mi
         Evaporative                 2.0  g/test(1)
         Particulate                 0.20 g/mi(2)
For 1993 model year light-duty vehicles, the California exhaust emission compliance requirements involved a less stringent carbon monoxide standard of 7.0 g/mi (vs. the Federal standard of 3.4 g/mi) and a more stringent NOx standard of 0.4 g/mi (vs. the Federal standard of 1.0 g/mi) and optionally higher hydrocarbon, carbon monoxide and oxides of nitrogen emissions.
And the 964s were certified at;
Code:
MANUFACTURER        CERTIFICATION LEVELS
  ENGINE FAMILY/EVAP-EMISS FAM        EXHAUST EMISSIONS      EVAPOR.
    (DISPLACEMENT)                                                        T                            (GRAMS/MILE)        EMISSIONS
   CARLINES COVERED                                               ENGINE  R    EQUIV                                        (GRAMS)
        DISP.&  A  S TEST   ACT.                         OXIDES
                     VEHICLE CARLINE                              CARB    N  I WEIGHT DYNO AXLE  HYDRO-   CARBON     OF     HYDRO-
                         REPRESENTED      EMISSION CONTROL SYSTEM VENTURISS  L (LBS)  HP   RATIO CARBONS MONOXIDE NITROGEN  CARBONS
PPR220V5FC26 / PPR1084AYPOC                        ENGINE-SYSTEM COMBINATION # =  1
    (220-CU.IN.)
   911 CARRERA 4/2   C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI L-4 N 3500   7.1  3.56   0.24      1.6     0.14      N/A
   911 CARRERA 4/2   C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI L-4 N 3375   7.1  3.67   0.22      1.8     0.14      1.6 *
                     C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI M-4 N 3500   7.1  3.56   0.23      1.6     0.14      N/A
                     C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI M-5 N 3500   8.1  3.33   0.25      1.6     0.18      N/A
                     C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI M-5 N 3625   8.8  3.44   0.22      1.4     0.19      N/A
                     C 911 CARRERA 4/2    3CL/   /   /   /   /CAN 220-FI M-5 N 3500   7.1  3.33   0.29      1.6     0.16      N/A
     (EXHAUST DETERIORATION FACTORS FOR - 3CL/   /   /   /   /     FAMILY PPR220V5FC26          : 1.300    1.200    1.100     N/A )
     (EVAPOR. DETERIORATION FACTORS FOR -    /   /   /   /   /CAN  FAMILY PPR1084AYPOC          :  N/A      N/A      N/A     0.400)
3.8P&Cs shouldn't increase emissions that much, is CARB certification even required for internal engine parts?
Old Jan 25, 2005 | 04:04 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Originally Posted by garrett376
I don't know for sure, I but I think just going with 3.8 p/c's won't get you to 300HP.
I am, though, very interested with the details, too, of what goes into reaching the 300HP level - I know Adrian's webiste goes into it a bit.
If I were to make a 3.8 that might have a chance passing CA smog, I'd go with 3.8 p/c's, titanium springs and retainers, mooned cylinder bases, knife edged crank. Using the stock DME, exhaust, cams & injectors will hopefully keep it smog legal - but not as powerful as it can get. I don't know anyone that has a 3.8 that's smog legal... do you?
To the best of my knowledge nobody (includes RUF, Sportec etc) can supply such an engine conversion which can pass CA smog regulations.
They can actually pass the test but they cannot pass the requirements to be allowed to be fitted or converted and fitted.
If you check with RUF you will see that their cars are only 49 State legal.
The testing done for certification by TÜV in Germany is no longer acceptable to CA.
A way around this is being looked at but take care in spending your money and always ask for CA certification paperwork or contact the CA authorities first.
Ciao,
Adrian.
PS: The Sportec 3.8 litre conversion passes all actual smog requirements including CA, Swiss (just as tough as CA and includes noise emissions tests as well) and delivers 320hp.
However CA will not accept the data because it does not meet their 50,000 miles of testing regulations which they kindly applied.
Old Jan 25, 2005 | 04:49 AM
JasonAndreas
Technical Guru
Adrian,
For your MAF kit can't you apply for an Executive Order in CA instead of going for the full CARB certification? How much do emissions increase with say a MAF or a 3.8 kit?
Old Jan 25, 2005 | 04:59 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Jason,
As I said this is under investigation but not by myself. I do not work for any of these people so all I can do is suggest and push a bit.
Sportec are in touch with CA regulatory authorities but if RUF could not get around the rules I doubt Sportec can either. However it will be attempted.
Ciao,
Adrian.
Christer's Avatar
Christer
Yep, its the smog thing that causes the problem. 300+ HP in a N/A 964 is easy but not cheap. I have around 290rwhp but I am totally pollutive. I don't run a CAT or anything else.
One thing about fuel consumption though, having installed Motec the fuel consumption has reduced to around 33mpg when cruising at 80mph. So on long trips if I take it easy I get actually better mileage....
Old Jan 25, 2005 | 05:13 AM
Youcef's Avatar
Youcef
My reply is not on subject so apologies in advance , but I just wanted to say that it sure is great to see Adrian around again. You were missed.
Old Jan 25, 2005 | 08:37 AM
DaveK's Avatar
DaveK
On the subject of power - I noticed the other day that a dyno has appeared literally 2 minutes drive from my house. I looked it up on the web, and it is a 4WD dyno. Although I did get plots once before, G-Force had some trouble stopping the wheels spinning - and since it's so close I'm tempted to pay the new place a visit. For £45 + vat - and since it's so close - it's pretty tempting.
Old Jan 25, 2005 | 09:16 AM
Monique's Avatar
Monique
Careful about dynos... 2 dudes from the 993 TT gang blew their viscous drives last weekend AFAIK.
Expensive...
Many Euro 964 RS's were brought to 300 HP... can't remember the most popular solution but might b worth investigating.
Old Jan 26, 2005 | 10:15 AM
Gavin's Avatar
Gavin
I have approx 265rwhp which, depending on what losses you want to assume is about 300ish Flywheel horsepower. These are the bits that got me there. Cost was in addition to top end re-build. Different cams, plastic inlet manifolds and later throttle assembly, enlarged throttle body, cup air box, K & N filter, de-cat, cup pipe, machine heads to raise compression ratio slightly, new valve springs, titanium retainers, RS flywheel and clutch, re-conditioned fuel injectors, re-chip running on shell optimax petrol. If you threw in 3.8 litre barrels and pistons you might get an extra 10bhp for £3000ish (parts only !!) Above this you're in Christer's territory, which I am sure he will confirm is quite expensive !!!
Car revs like mad, sounds awesome, is really good fun and is real quick for a fifteen year old.
Hope this is of interest.
