Performance ignition wires
Has anybody on the forum had any first hand experience of the Kingsborne high performance ignition lead sets for the 964?? They advertise their set number 09-791 as suitable for all C2 and C4 models and apparently use Beru ends. My concern is whether they have all the necessary grommets fitted to fit through the lower engine shield. Magnetec also advertise a set but say that they do not fit the grommets and, because of the plug cap they use, the lower engine shield has to be permanently removed.
Kingsborne are at www.kingsborne.com and the 09-791 set retails for some huge amount of money - but is it worth it?? And does it fit a road-going car with it's various bits of metalwork??
Any help appreciated.
Regards
Dave
Regards
Dave
You can easily cut a slit in the old grommet, and slide your new wires into the holes through the slits you make. This way you can get some good wires, and keep your grommet!
Technical Guru
If your looking for a performance gain by replacing spark ignition wires your only wasting money, there is nothing to be gained. If your worried about the engine capsule grommets then ask Kingsborne if they use the twist-on Beru end connectors. If so you can just buy the grommets from Porsche for a few dollars and twist pull the ends off, push the wires through the grommet and then twist the connectors back on (no need to cut the grommets/seals). Also, it might be cheaper for you to buy wire, connectors and a crimping device directly from Beru.
Technical Guru
There is no need to cut the grommets that attach to the sheetmetal (which is also what I thought he was talking about). You can just unscrew the connectors and then pass the wire through the grommet.
Guys,
I think I might be misleading myself - as well as you. From the little I've read (and been told by Magnecor) I believe there to be grommets located in some metalwork through which the lower plug leads pass on their way to the lower plugs. I was led to believe (again by Magnecor) that THEIR lead set does not have the grommets and they also use a shorter plug cap so they seem to advise that the lead set only be used on competition cars (where the metalwork is likely to be discarded anyway.
I wasn't expecting to get any performance increase by merely changing the plug leads but there is a chance that mine are due for renewal and I just fancied a red set rather than boring black. No functional advantage whatsoever - purely visual!!
I was just looking for some practical advice from someone who may have bought the Kingsborne set and their experience.
Thanks for the responses.
Regards
Dave
Regards
Dave
Technical Guru
It's not a good idea to change from stock Porsche ignition wires, as the ignition
system can be very problematic with the DME control unit causing random poor
running and DME faults.
