Garage "Up"date
Lifts are great aren't they, makes changing that clutch so, so easy. Being one that started out with VW's then graduating to 911's I know the benefits of having a lift and don't thing I could ever live without one. Looks good Jon.
The door and door opener arm are close, a couple of feet. I am going to remove the shelves behind the lift to allow me to move it in another 2.5 feet or so.
Here is a picture with the door up:
It is a Team Lift, SS7000 with a 220 Pump. I got it through American Automotive Equipment. Here is their url American Automotive Equipment . They also sell on E-Bay.
John:
I noted that you raised the door opener up closer to the ceiling. Where did you get the extension form the door opener drive to the door itself? It looks a few feet long.
Great idea. I have a similar set up and I always thought I was going to have to also raise the door rails. Apparently not, it does look tight though.
Congratulations, job well done.
Dave,
I did have the door rails raised, you can sort of see it in the open door picture. I also had a 10 foot door opener installed, which included the extended arm for the door. Basically it is four pieces bolted together.
John, the project looks great! I know you were looking forward to this. You've inspired me to get a tape out for my garage to see if this will work.
How long does it take to raise/lower the car on the lift? (You can see where my evil mind is headed, I think!)
Joe
Joe
