Engine Carrier
Technical Guru
Engine Carrier
Does anyone know what the torque specifications are for the four 10mm nuts that attach the engine carrier 964-115-021-90 (suspension) to the engine studs?
If that is a 10 mm nut, I believe the stud would be 6 mm diameter, or M6. I don't know the factory recommendation, but "Fastener Facts" torque table for a Property Class 8.8 M6 nut is 95 in-lb (8 ft-lb) dry, and 57.5 in-lb (4.8 ft-lb) lubricated. Property Class 8.8 is the same material as the SAE Grade 5 (heat treated) fasteners. The torque value for Property Class 10.9 (like SAE Grade 8) is 132 in-lb dry, and 79 in-lb lubricated. Please verify the stud diameter is 6 mm before using any torque spec.
If I did not know what the Property Class was, I would put thread paste on the threads ,and torque to the lubricated Class 8.8 value. The studs and nuts may be Class 10.9, but the stud is in the aluminum case. I am surprised there is not a hardened flat washer between the nut and the metal plate. Did the factory leave it our, or are your's just missing? A hardened washer considerably improves performance of this type of bolted connection.
Edit - first post had "ft-lb" where units were "in-lb"
Sorry, I have been playing with bolt failures a lot at work lately, and perhaps am getting too technical.
A hardened flat washer is needed any time a heat-treated (hard) bolt or nut is used to clamp a non-heat-treated (soft) steel part. A hardened washer spreads the load to prevent indentation of the softer steel by the hard nut. The washer itself must be hardened so that it does not indent. Any indentation will cause the clamping force to decrease.
If the clamping force gets too low, two bad things can happen:
1) Vibration causes the nut to back off. A properly tightened nut will, by design, resist vibration.
2) The parts get loose enough to slide. For a number of reasons, threads should not be loaded in shear. They can break under shear loads. If the stud stays tight (and is designed properly), the shear load is taken by friction between the parts, and all the stud needs to do is apply clamping force.
Bolts are so simple even a young child can understand how they work. Bolts were in widespread use before engineers and scientists studied them enough to understand them properly. You have to know a lot about elastic theory and friction theory to understand what is going on. Bolts are not particularly forgiving. The best way to avoid a mistake is to trust the factory design and follow the maintenance instructions.
Technical Guru
I've decided to replace every fastener thats come off my car with a new one so I've spent way too much time over the past couple of months learning about fastener specs so that I would make sure I buy the correct nut, etc. I was amazed at how inexpensive it is to buy all new fasteners the only problem being the minimum order requirements that most businesses have and the sheer number of different types of fasteners that I had no idea existed. In 99% of the cases it is still cheaper to buy a box of 100 than it is to buy 5 from a Porsche dealership. I just wish that Porsche would have provided a listing of every fastener, DIN spec and torque specification used on the car like they did for older 911s.
Jason:
M10, property class 10.9 torque spec is 53 ft-lb dry, and 32 ft-lb lubricated. If you use Loctite, I suggest going with a lower torque just to make sure you don't pull the stud or crush the washer. The lubricated torque for an M10 Class 8.8 nut is 23 ft-lb. That shoud be plenty tight, but not risk damaging anything else.
I know replacing fasteners is a budget buster. Why are you not reusing the less critical ones?
Technical Guru
Jason:
Jarhead
You guys are my heroes. I'll never know half as much about the mundane bolts on my car as you guys do. You both are truly paradigms of Porsche ownership. Thank you.
Brian
Brian
