Help!! Sunroof Height Adjustment
My sunroof opens and closes fine but the drivers rear corner is a little low and requires adjustment. I pulled off the inside cover and found a small flat head screw that seems to be the height adjuster but it just turns but doesn't seem to tighten...is there a nut on the other side...does anyone out there have any advise or is the screw just stripped????
Thanks in advance
Thanks in advance
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Lifetime Member
Lifetime Member
Hi, DB.
You might want to look on the Pelican Parts site - I seem to remember there is an article about removing and refitting the sunroof.
O/T - I see you are a fellow X1/9er - I had 2 1500s years ago and am trying to decide this weekend whether to buy an immaculate 1977 1300. One owner, 18k miles and all-original!
( No rust!!!).
I adjusted mine ages ago and I don't remember it being a flat head screw. I think it was a knurled wheel - but there is an adjuster for the front and one for the rear - and the rear one is not easy to get to.
thanks for the info. It looks like i'll take the sunroof panel right out to get a better look at the screw to see if it is stripped.
I love my little fiat x/19, It was my first car purchase @ 19 years of age and it has great sentimental value
Derk, how did you end up fixing this? I think I have the exact same problem as you, the rear driver's side corner of my sunroof sits a little low but the sunroof operates fine. I was planning on fixing it soon, any guidance you can give would be much appreciated.
Look at the third picture in this Pelican thread
http://forums.pelicanparts.com/porsc...-87-911-a.html
See the knurled fittings between the bracket and the sunroof that the 8mm bolts go into. Those adjust the height on the sunroof. It was a bit of trial and error for me.
Pic three shows the adjustment for the front. Pics 4,5,6 & 7 show the flat head screw that adjusts the height of the rear.
The screw screws into a toothed piece of metal which engages with another toothed bit. Loosen off the screw a few turns push the panel up to the correct height and tighten.
i noticed that when I took the headliner down this weekend. was wondering how adjusting the front would lift the rear. took a little while but i figured it out. should have read this thread once more before i began. tks for the info.
I have a bunch of pictures of my sunroof removal and install here if you need any images:
http://picasaweb.google.com/udoreisinger2/Sunroof#
Oh, and don't forget: "the spring should be below the rod but under the tang" LOL!
https://rennlist.com/forums/showthre...ferrerid=19642
