Speed Pulse for GPS
#31
We tried a different brand new GPS to rule out a faulty unit. It will get a speed pulse from the CCU and spoiler control module, but only at select speeds, not a continious range beginning at 0mph. I try to keep this thread bumped because I know someone has suffered this same scenario and can help with the solution. Tomorrow we are going to try the black/violet from the central informer. This is one wire the porsche manual says is a speed sender wire that we have not tried. The other solution would be if we could find out where to catch the corrected speed pulse , there is supposed to be a unit that recieves the signals from all 4 wheels then corrects the signal by dividing by 8 or something like that. If I can find that corrected signal maybe I can tap in there without affecting the ABS.
#32
Well, today this issue is solved. We had to add an Alpine Speed/Pulse sender unit and magnetize 135 degrees of the right front tire. But it works perfectly now. It just shouldnt have had to come to this. I am just glad it is over. Now I can ride and enjoy.
Thanks to all of you that provided your input.
