power window help needed
Help!!! My drivers side power window quit working.... it will go up fine but will only go down if you push it or use the method in the owners manual to do it manually... when the button is pushed for the down mode a clicking sound is heard from the window motor... does it have a set of contacts or relay on it? The door panel is off and there doesn't appear to be any binding or regulator problems and the window is on track. Any ideas? Thanks, Mark 91 C2
