Greatest fear what will brake in the future????
Originally Posted by Arjan B.
Surf Twang........
I am sure you have second thoughts about certain parts on your car that concern you.
I think he's more concerned about parts on HIM at this point!
I obsess about everything on the car. Adrian's book has helped me find more things to worry about. Main fears - DMF, dist. belt, AC wtih r-12. But I try to have perspecitve, these are really only money troubles that can be repaired. Not everything in life is that way. If all I worry about is a flywheel, then I've got it good.
Suspension- replaced
Alternator- replaced
Clutch and flywheel- replaced
Valve springs and retainers- replaced
Little bits and pieces- replaced as needed
Brakes and tires- replaced regularly....
Next up: Synchros- (the one between 2nd and 3rd gear is starting to fail....)
mj
mj
May be a tiptronic is the next option for you SUF TWANG.........
I love to hear you have fun with the car, great! How about a little voice inside your head who says, TWANG......twang.......listen to the wierd sound in the back............. Hello.....anyone home???????
Well I am lucky, my car is almost new....
Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen, Nothing bad will happen,
The best thing to get rid or all your worries about the little noises and rattles in your 964 is a good stereo system.
Turn up the volume on Meatloaf or something equivalent (absolutely no rap or ooomf-ooomf music) and drive it on.
