Spoiler Malfunction
With much searching I have not found anything that addresses an issue that began yesterday.
My spoiler has become non functional. Speedometer is functioning normally, and the warning light stays on at all times. No function from the manual switch either.
Where to start?
Where to start?
Check for +12V power & ground at the module. We'd repaired a number of these modules lately.
A good start is to determine if there are any mechanical problems, then onto the electrical as described in the page linked by 54064.
If all this is OK, I would have the control unit repaired. These are known to fail in many ways, component failure, soldering problems etc. I change a small handful of components when repairing these.
Cheers,
Tore
Cheers,
Tore
Since I am not experience the partial/intermittent failure that most seem to have, my first thought is fuse/relay.
Cheers,
Tore
Cheers,
Tore
Or should I just finally go duck? hmmmm
If the spoiler stays up all the time I have found after fixing a few recently that it is the control module on the later single control module cars.
If @systemsc repairs these I have one I need to send out so I can get my good one back. He has been very helpful in the past.
Same issue here. Everything was working well after a new motor, a new "gearbox" and a new T Spoiler controller from Tore at Bergville. Car sat for about a year (sorry I got distracted tracking a Cayman). I put in a new battery and driving the car again. Now spoiler is "inop".
Just found the secondary controller under the seat and removed it per Tore's instructions for the T Spoiler controller. Still no joy. Going to follow the instructions here, as previously described. Let me know what your results are
Rear Spoiler Mechanism Troubleshooting
