964 Engine Case Composition
I know it's aluminum, but does anyone know if there is some sort of mix in there? Like possibly a certain amount of magnesium or any other material that the case is composed of other than straight up aluminum?
Cheers
A356.0T6 is the alloy used for most cast aircraft or military parts in the US. I suspect the case is similar based on what I see. Although it is possible it is closer to 355.0T6 which adds Copper to withstand heat and retains its strength at higher elevated temps. I used to cast engine cases for the NASCAR truck series decades ago out of this alloy. It is an alloy my grandfather pioneered along with ALMag 35 & AZ92 magnesium AKA Dow metal with Dow chemical when he headed Bendix Eclipse Pioneer back in the 30's.
You can always send out some shavings or grindings from the area for chemical analysis. If you do I would be interested in learning what the alloy is. It is also tempered so as said you will destroy the temper if welding the case. Normally a part is heat treated to a T5 solution treatment then welded and artificially aged to full T6 after the welding is done. Make sure he clamps it flush to a table to prevent warpage.
GL
This is a 964 engine that was in an accident and the header snapped off a chunk of the threads where the oil supply line threads into the case. Fortunately it was a clean break and I don't see any distortion so it mates up very nicely. Seems to me like a pretty straightforward repair, but don't want to take chances using the wrong TIG rods. The threaded pipe still threads in smoothly when I mate the broken piece up to the case and the threads all still line up nicely and the pipe turns without resistance.
So I was told to clean it, clean it again, and then again. Grind out a little bit of material all along the outside edge of the break to create a "v" so the TIG has something to bite to, and clean it again.
But the welder asked me to find out what that case is made of to determine what type of rod to use.
You might be able to have something made to replace the broken piece and weld it in place using the oil line from a 993.
I have no doubt you can come up with a solution. If you weld the piece in place you can also make a plate that holds the insert or threaded adapter in place taking any strain off of the casting. You can use both threaded holes on either side as well. Just a thought.
GL
993 engine with newer style approach to keeping the pipe in place.
As an aside here is some info on A6061 It has a German origin in 1935 hence my guess on the case composition:
Casting 6061 T6 Aluminum6061 T6 aluminum is a popular alloy for casting due to its excellent combination of properties, including:
- High strength-to-weight ratio
- Good corrosion resistance
- Versatility for various applications
Die Casting
Die casting 6061 T6 aluminum is a common method for producing complex shapes and intricate details. The process involves injecting molten aluminum into a metal mold, or die, under high pressure (typically 10,000-20,000 psi) and temperature (around 900°F). This results in a dense, accurate, and durable casting.Heat Treatment
As-cast 6061 aluminum is often soft and prone to distortion. To achieve the T6 temper, the casting must undergo heat treatment, which involves:- Solutionizing: Heating the casting to around 980°F (520°C) to dissolve the alloying elements.
- Quenching: Rapidly cooling the casting to around 400°F (200°C) to precipitate the solutes.
- Artificial aging: Holding the casting at a specific temperature (around 350°F or 175°C) for a set period to allow further precipitation and strengthening.
Comparison to Other Materials
6061 T6 aluminum die casting can be compared to die cast ZA-8, a zinc-based alloy. While both materials have their strengths, 6061 T6 aluminum offers better corrosion resistance and higher strength-to-weight ratio.Challenges and Considerations
When casting 6061 T6 aluminum, it’s essential to:- Control the pouring temperature and pressure to minimize porosity and ensure proper filling.
- Use a suitable mold material and design to prevent sticking and ensure easy ejection.
- Perform proper heat treatment to achieve the desired T6 temper.
- Consider the potential for warping or distortion during cooling and handling.
Further, excellent weldability!:
The 6061 aluminum alloy was developed in 1935 in Germany. Initially, it was referred to as “Alloy 61S”. This precipitation-hardened aluminum alloy contains magnesium and silicon as its major alloying elements.
Key Characteristics
- Good mechanical properties
- Excellent weldability
- Commonly extruded (second in popularity only to 6063)
Tempering
The alloy is available in various tempers, including:- 6061-O (annealed): maximum ultimate tensile strength ≤ 150 MPa (22 ksi), maximum yield strength ≤ 83 MPa (12 ksi) or 110 MPa (16 ksi)
- 6061-T6 (solutionized and artificially aged): ultimate tensile strength ≥ 290 MPa (42 ksi), yield strength ≥ 240 MPa (35 ksi)
Applications
The 6061 aluminum alloy is widely used in various industries, including:- Aerospace and defense technology
- Shipbuilding and marine construction
- Automotive and vehicle manufacturing
- Electronic devices (e.g., laptops, smartphones)
- General-purpose structural applications
German Standard
In Germany, the 6061 aluminum alloy is specified as EN AW-6061, which is part of the AlMgSi alloy family. This material is used in various applications, including vehicle, ship, boiler, and tank construction, as well as defense technology and aerospace.More!:
https://at-machining.com/6061-aluminium-alloy/
This crack is heading near one of t he 4 mating bolts to the trans. Where does it end?
An expert repair is recommended.
And here is the outcome. Welded up pretty nice. He added lots of material which is fine with me. I filed the mating surface flat so the crush washer will do its thing. I plan on getting some jb weld or marine tex and filling the cracks on the inside of the threads, then putting more of it on the threads of the oil line that screws in there, give a good snug, and never touch it again. Fortunately, the oil line has its own nut and I can tighten it without needing to do anything more than holding this one in place.
I hope it works. It'll probably be about a month before I get this motor in my car so until then I'll just have to wait....
Die Casting
Key Characteristics
Tempering
Applications
German Standard
Interesting internet info. As a retired 30 year veteran and 1st tier supplier of Aluminum and Magnesium sand castings for the US aerospace and defense industries, this is a first I have heard of using 6061 for castings like this. 6061 has poor fluidity due to its low silicon content. It is commonly used for plate, pipe tubes etc. Mostly parts are machined from it and not cast although I have been retired for 10 years so times may have changed. Unless you have info other than what is on the internet I still don't believe it would be 6061. I know of one foundry that cast it but they used a centrifugal process but for small parts only. If it was used it would need to be Die or Pressure Cast but again not in sizes this large and it would never flow properly as a sand casting.
If you have any info stating that 6061 was actually used for these cases I would be interested in seeing it. Although like the rest of the cast parts Porsche used I suspect the Si content is higher for fluidity and would be closer to the 356 or 355 alloys.
@drola I do agree with @Bustednukel I would be hesitant to use it like that. Without securing the pipe I suspect over time vibration will cause the weld to give.
drola, added a new blue arrow to same crack in your finish photo that has now expanded due to welding heat. Will likely propagate further in the general direction of the mating stud to the trans.
I still would have just welded an AN fitting onto that neck.
I have a spare case. If I can find a place to remove some shavings I can send them out for wet analysis since I don't have a large enough piece to do a spark test. It would be good to know for future reference in case this happens to someone again. It is interesting that you reference Miguss Peter Mies GmbH, Hellinghaus Germany When I purchased my house back in 1999 my neighbors son who I had just met moved to Germany to work for them. He was a very talented foundry man but IIRC they were not at the level they are today. I no longer have his contact info or even know if he still works for them but If you get any info from them please post it. Always looking to learn everything there is about these cars and usually learn something new everyday.
I usually see the trans cases fail from accident damage and also the fork lugs can crack off and they usually get weld repaired or they get machined off and new pieces welded in place but you need to hone the opening to precise dimensions. Without the inside of the opening welded and tapped I wouldn't trust this personally. I would use the 993 approach. You can weld a plate to the threaded insert and bolt it to the case. This would at least insure it doesn't break off easily in case the weld didn't penetrate properly. Then use a sealant like 574, Threebond or other engine sealant to make sure that oil doesn't make its way through any porosity that is left from the welding process.
GL
My admin skills are pretty good and with a thin veneer of expertise. Shouldn't we also send one to Porsche AG? Certainly the group knowledge here has a contact.
"Hello folks at Miguss,
While researching for composition of Porsche engine cases, your company was identified as expert in casting EN-AW6061. I have guessed that this process may be similar to the one used by Porsche on their 911 model produced from 1989 through 1994. Porsche's internal code for that model year's car was 964. Our interest in the identification of the case material and process to manufacture is related to the proper repair of cracks or other damage. Particularly the fill material for such repair needs to be identified in addition to the actual case material.
Our interest in this project is shared with others who are passionate about Porsche cars on Rennlist. Presently we are trying to avoid mis-repair of these cars and seek any knowledge or direction you might care to offer. We believe an exact answer may be resident with folks like those at Miguss and your community.
Many thanks and best regards,
Signed "
