door chime sounded like donkey-kong...
Thanks everyone! Adrian, I knew you'd know what that box was - thanks! So maybe my gong relay is fading out!!! Will have to check/replace that and see where it goes from there...
Springer3- I think the temp sensor is on the same panel as the AC unit controls... no?
Great board - you can learn something new every visit.
Hey Springer3, it appears that speaker-thingy near the tach is a different warning beeper - it only goes off when the hydraulic pressure on my C4 is low and I start to drive around before it's up to pressure - that happens only every once in a while when I'm impatient! I think it might also be used on cars that have a "speed limit" warning - or maybe it's only a C4 thing?!
The "gong" sounded like it comes from the central informer itself when I was tucked under there listening...
it appears that speaker-thingy near the tach .... ....only goes off when the hydraulic pressure on my C4 is low.... ......maybe it's only a C4 thing?!
Before anyone gets started, I admit I need to get a life!
Technical Guru
Now we have a mystery. What does it do for a C2? Is it one of the vestigial remains of our C4 ancestry?
Oh yeah, I had it go off when I got the ABS warning light. Which would come on intermittently, usually after hitting a good bump in the road. Problem turned out to be a lightly corroded ground connection for the control unit. I had never heard it before in 10+ years of ownership. When it went off, it really got my attention--I thought she was gonna' blow!
Just a followup - after disconnecting the plugs to the central informer, the gong sounds normal - has not sounded "sick" since. Seems to have done the trick.
Makes you wonder if that should be a regular maintenance item - jiggle the plugs everywhere!!
