TOO MUCH HEAT!
Hi guys/gals, how to access valves that control heat manifold heat traveling thru floor channels and up thru front floor footwells? Think it's my source of excess heat overwhelming my ac! Also, rear engine compartment fan no workee. Tore's guide points to the resistor in the fan's "duct". Anyone know a source or anything about it? Many thanks, Tom
Here's how to check the mixer servo motors, controlling the hot air flow to the cabin, as well as test procedure for the rear fan: https://www.bergvillfx.com/categorie...test-procedure
Cheers,
Tore
Cheers,
Tore
Hey Tore, as usual, many thanks for the info! I jumped the compressor relay and it was bad. Still haven't
gotten rear fan to come on due to size of aftermarket In- tercooler, it's a "B" to get at. If the motor Is bad, I'll look into getting it rebuilt, damn things are over $900 US! Thanks again, Tom
