Widest seats for a 964?
I have the factory non sport seats and they pinch my *** over long distance drives
almost makes my legs go numb
it didn’t happen in my 993
looking for wider seat options
I'm not a huge person
6 feet 195 lbs
dad bod but not husky
6 feet 195 lbs
The stock seats are like that for me as well.You could pad the lower middle cushion to raise it up a little. Also you might consider these:
https://www.recaro-automotive.com/us...s-sportster-cs
i have the sportster version with the side boosters and I find them very comfortable relatively.
pete
pete
The following 2 users liked this post by 0luke1:
jeff33702 (07-09-2024),
MNpcarlover (07-05-2024)
I had the same problem. I took out the seat and loosened the cover. This gives access to the metal bar that supports the seat bolster on each side. Using a pry bar I was able to bend the bar a little towards the outside, maybe 0.5 cm on either side. Now the seat is a lot better. It didn't have to move much. And the seat looks exactly the same.
Peteinjp (07-10-2024)
