NB Tire Sizes
Looking to upgrade the wheel and tires on my NB. Going to go with Fuchs 17x8 et52 fronts with 235/45/17 tires and 17x9 et55 255/40/17 for the rears. From what I’ve read this setup works for a NB front. I’m lowered on MCS coilovers with the updated tie rod spacers. Hoping to not have any rubbing up front. Anyone else running this setup?
On 17x8 and 17x9 I am running 225/45/17 front and 255/40/17 rear. The 225/45 and 255/40 are the same diameter, which is nice. I don't miss the extra 10mm of tread width.
cool, what tires are you running? Good to know re: the fronts. I read the 235 was what was used on the cup cars? I’m at 205 right now so 225 or 235 is going to be a nice step up in the right direction.
You can use those, but JMO 225/40 is a better choice for the front. the 225/on an 8 is better fitted than 235 on 8, Now if you used 235 or 245 on 8.5 that would be different.
thanks Bill, you’re a wealth of knowledge and appreciate the input. 225/40 it is.
You are getting down to nuances here, besides optics the difference is a better support/leverage w/ the 8 which raises the grip level a bit at the cost of a bit ride comfort..
lfl215l (04-12-2024)
Front 17x8.5
ET 50.4mm
235/40-17 Nitto NT01
Tire diameter 24.4 inches
Rear 17x10.0
ET 56.7 mm
275/40-17 Nitto NT01
Tire diameter 25.55 inches
5 mm spacers in the rear
longer wheel studs
Rear fenders lips rolled
oil line on right side flattened slightly
Control arm edges polished smooth in the area where the tire might rub (it does not)
Track alignment, track springs, track ride height
