Need PPI shop in Lexington, Kentucky (C4 possible purchase)
Looing at an '89 C4 there...
any advise?
what should I have them look for?
also what is the going price on an '89 w/100k?
any advise?
any advise?
any advise?
Distributor vent kit needs to be installed if it's not been fitted since they did not come with a vent kit from the factory
Early '89 C4's might need a rear tail lamp vent kit since the very first '89's didn't have this...
The '89's do not have the dual mass flywheel, so that helps in that department.
Check all electrical accessories to insure they all work, and, most importantly, insure all the warning lights that need to come on when the key is first turned on do indeed light up. It's becoming common to hear about prior owners removing warning light bulbs to mask electrical problems.
I agree with Paul in that an '89 with 100k would be in the $18k to $20k range depending on it's condition. Less than $18k if it's very rough...
Good Luck,
Jay
90 964
from what I've heard from the mechanic that works on the car is there is an oil leak coming from the cylinder head...is this the "cylinder head issue"? it is very minor from what he stated...
also the transmission downshifting from 3-2 is "slacky" (his term) has been for over two years, but doesn't cause issues...is this a tranny rebuild waiting to happen?
they did a leak-down recently, #2-3 were at 67-68 while the rest were in the 70's...is this something that I should be concerned with?
Thanks again for all the help...as a 911SC owner i know what to look for, but these are a different animal...
Kevin
Kevin
