964 Forum 1989-1994
Tachometer Stopped Working
Old 09-20-2023, 04:55 PM
AFKC
AFKC's Avatar
Default Tachometer Stopped Working
My turn signal indicators still work/illuminate. Anything I can check before I pull it out and send it off to see if it can be fixed?
Thanks!
Old 09-21-2023, 02:30 AM
ToreB
ToreB's Avatar
Of course it can be fixed. However, I would check that it gets power supply before proceeding with any repairs.
Working turn signals/high beam bulbs only proves that the GND connection to the instrument is OK.
Is this a tachometer with the OBC option or not?
Cheers,
Tore
Old 09-21-2023, 09:59 AM
AFKC
AFKC's Avatar
Thanks, no mine doesn't have the OBC option.
Old 09-21-2023, 04:07 PM
ToreB
ToreB's Avatar
Non-OBC tachos have pin numbers and function printed at the back. Check for ignition switched 12V at Terminal 15, pin 7. GND is pin 2.
Cheers,
Tore
AFKC (09-21-2023)
Old 10-18-2023, 11:58 AM
marty964
3rd Gear
marty964's Avatar
I’m having a similar issue on my 1990 C2. The tach is completely dead and stuck at zero - my power windows and power mirrors and windshield wipers also died at the same time. My seats radio lights and signals work. Not sure where to begin, but I think I’m chasing a bad ground somewhere. Wiring diagrams could help me out.
Old 10-18-2023, 12:14 PM
ToreB
ToreB's Avatar
Start with checing the fuses. Then, read post #4 in this thread.
In my opinion, "Check grounds" is the most common time-consuming and misleading fault finding tip on these modern cars.
Cheers,
Tore
