System Adaptation Issue
Gents - I’ve read as much as I can on the issue, but not finding anything on point.
Disconnected battery last weekend to replace the starter. Once reconnected with all grounds / connections double checked, the DME doesn’t seems to be permanently adapting. Never had this issue before, even after other battery disconnects.
Every time the car sits for any decent length of time, it needs to relearn again to run right. I tried letting it sit and idle for ~30 min with no inputs, driving aggressively, driving normally, etc. Still runs like garbage on startup for about 10 min.
Frustrated. Any ideas ?
I guess you need to do the OBD diagnostic Idle Adaptation procedure.
You need a Porsche-compatible OBD tool.
Cheers,
Tore
Cheers,
Tore
Potentially resolved. Drove just now after sitting all weekend and it started right up and ran flawlessly. Maybe I just needed to complain about the problem on RL for it to go away . . .
I find it takes a good half hour of driving for the car to do its own idle adaptation. My UDT999 will do it if I bother to plug it in and run the routine but so far I have not bothered.
The weird thing is, if I disconnect the battery only for a day or two it does not seem to lose the settings. If it sits disconnected for a week or more, then it takes a half hour ride to fix it.
I wonder if you have some other issue. I've let me car sit for a while several times and never notice any running issues. YOu're sure you're in good tune, no air/vacuum leaks, fuel issues, etC?
