Help.. 964 nightmare..
#31
It’s a pain for sure. Here is a great primer on how to read the diagrams if you find them as confusing as I do.
http://www.928-electrics.com/Docs1/P...WDP%20Only.pdf
The following 3 users liked this post by Peteinjp:
#32
This is what I was trying to say in post 12. You just have to dig in and go at it methodically. If you have questions like- “what does this in the wiring diagram mean?” You can probably get useful answers.
porsche964IRE (09-15-2023)
#34
No I am still not fixed
Will have a go with the wiring diagrams this weekend.
Thanks everyone for the help.
I have to figure out why the DME is only get 8/9V while ignition is on, So will chase the ignition DME wires or at least try.
The terminal X arrived and did not make any changes. Car is going in for refurb later in the month so would ideally have sorted by then.
#35
I've been doing some similar troubleshooting (my current problem seems to be fuel pump, so not the same as yours) which led me to trace the DME wires.
This involved pulling the Central Electrics board out of it's tub to get access to the big bad plugs on it's reverse. Note that there is a moulded plastic lock rail that retains all the plugs. If you want to pull the plugs, this tab must be slid back around 10mm. Do remember to pull the battery terminals before poking around here as there are plenty of live circuits. See sheets 5 and 11 of the wiring diagrams for much of this.
The positive terminal on the DME should be marked 30 on the relay unit and 3 on the central electrics unit DME socket (Relay 41). This socket connects to the "E" plug on the underside of the CE board to terminal E31 (i.e. 3rd column, 1st row).
E31 connects via a red 4mm loop wire across the back of the plug to E35.
E35 connects within the CE board (i.e. via the copper tracks) to G25. It also branches off to E25, which connects back to E21 via a 1.5mm red wire.
G25 connects directly to the battery via 4mm red.
E21 connects within the CE board to fuse 35 - the DME fuse. (also connects to D21 which I hadn't noticed before, though this seems to be unused).
Therefore if you have continuity between each of these points, I (as a DIY electrician with limited skills) can only put your low voltage down to poor earthing on your meter probe, a problem within the DME relay itself, or an issue within the DME control unit. Between which connections are you measuring the 8/9V?
Z
Z
#36
Hi guys,
I have had an ongoing issue with my Porsche and with no useful mechanic in my area willing to help I intend to fix this problem at last by myself, with the help of this forum
I have a 964 C2 manual that will not start.
She splutter starts usually on the third attempt when cold,
When hot she turns and turns but no luck starting,
I have put in a brand new fuel pump,
I have put on a brand new aftermarket DME from design911,
When I take off the old DME relay cover I can manually prime fuel pump and she starts perfectly,
The car is idling/running and driving perfectly in general,
I have just got immobililser inspected and removed, which I believe it was already removed as it made no difference to starting issue but got charger €350 all the same...
The fuel filter I'm told was replaced two years ago, ±500 miles ago, and only ever e5 fuel.
Attached video is after 3 mile drive.
Please help. Thanks
Please help. Thanks
#37
#38
#39
Update.
Still not fixed, today when I went to it the battery was low, however the DME worked perfectly, did the same again later. But when I put battery charger/jumper on the battery the DME stopped working as it should.
I jumped a new wire from Pin 86 to battery positive for test purposes which the DME works as it should but of course this is not a fix, I must run a new wire from pin and attach it to a fused ignition plug. Any suggestions?
Or reading a different rennlist forum could my problem be a poor ignition switch? https://rennlist.com/forums/964-foru...ng-else-2.html
#40
I replaced mine couple of years ago, it solved a strange issue with my headlights. A fairly inexpensive item to replace, I noticed when I jiggled my key the lights would go on and off.
#41
Basic Sponsor
Update.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
#42
After spending lots of money on "genius" mechanics I give up on mechanics, €150/hour labour for the guessing and looking into a hole.
I am not leaving my pride and joy in anymore "geniuses" yards for them to be poking around the wiring and leaving it outside.
I have decided to fix it in the following way and would like advice, I will cut and run a new wire to DME pin 86 from the back of ignition. I would like to know which wire I can join onto at the back of ignition to insure the DME gets full 12v when the ignition is on and none when off.
Or could I join wire from pin 86 to a fuse wire and piggy back off existing loom without needing to enter cabin like radio etc.
Thanks.
Thanks.
#43
Thanks.
Thanks.
Have I any suggestions on what wire to connect to? Maybe test continuity for a wire heading from terminal X?
#44
Did you fit a new crank sensor? If not I am sure it will solve your issue. I fthe car is still on the old type sensor you may need a holding bracket and a change of plug on the wiring. If it uses the later 996 sensor its an easy swap with the car on a lift.
porsche964IRE (12-27-2023)
#45
Solved
After a long time of self diagnosis and misdirection from mechanics I stuck with my incline of immobiliser fault, after a long time of figuring out the wires and diagrams I removed the immobiliser function to original and no issues since, all working perfectly.
The following 6 users liked this post by porsche964IRE:
Harold (01-22-2024),
John McM (12-28-2023),
johnjohnc2 (12-28-2023),
Ken D (12-28-2023),
misteralz (01-03-2024),
and 1 others liked this post.
