964 Forum 1989-1994
bleeding the PDAS using the Hammer... - piece of cake!
Old 05-21-2004, 03:20 AM
garrett376
garrett376's Avatar
I was pleasanly surprised how easy the process was. Now my PDAS system should be good for two more years, according to the service recommendation! Then I'll be back under the car again, but with yellow brake fluid this time!!!
I hope you all enjoy! I always was curious about the Hammer and how it worked; was fun to get to do it myself!!
...and now an off topic picture of some Porsche fun in the old beater...
Old 05-21-2004, 10:04 AM
Ruairidh
Super Guru
Ruairidh's Avatar
Interesting stuff, thanks for posting.
Old 05-21-2004, 11:50 AM
axl911
axl911's Avatar
You know. The biggest problem I see with that tool is that YOU HAVE TO WASH YOUR HAND EACH AND EVERY TIME YOU USE IT B/C IT IS SO NICE.
Old 05-21-2004, 12:09 PM
garrett376
garrett376's Avatar
Funny you say that - the Hammer is graciously "leased" so it's not mine - I wear gloves when working on the car so I would just take off the gloves each time I had to press a button!! That was the hardest part of the procedure, to be under the car with gloves on, turn the bleeder, take off the glove, press the button, then press it when it's done bleeding, then put back on the glove to close the bleeder! I thought of putting a plastic bag over it!!
Old 05-21-2004, 01:01 PM
BaysideC4
BaysideC4's Avatar
Fantastic post! Thanks for documenting that procedure. Now I just need to get my hands on a hammer.
Old 05-21-2004, 04:56 PM
springer3
springer3's Avatar
My lease rate for the hammer is $25/week plus a huge refundable deposit. Garrett just proved it works for PDAS, and might soon be able to vouch for getting his deposit back.
I have tried its other functions on my C2, and I am quite impressed with the capability it provides. This thread makes me wish I had a C4!
Old 05-21-2004, 05:04 PM
Jeff Curtis
Jeff Curtis's Avatar
Yeah, that is a GREAT deal there Paul, the deposit is warranted as well.
ONE question though, is there an option to operate the ABS pump up front that goes to each caliper?? The procedure described so far are for the longitudinal lock and the "other" one (I'm not a C4 owner...sorry!)
I have heard that the Hammer can operate the ports for each caliper??
Anyway, good stuff there Garrett376.
Old 05-21-2004, 05:23 PM
vove
vove's Avatar
Good work Garrett..
Old 05-21-2004, 09:10 PM
springer3
springer3's Avatar
Jeff: The ABS is one menu I did not explore on the C2. I need to do some work now (see related post), and I will try to see if the Hammer will help flush the ABS system.
Old 05-21-2004, 10:47 PM
garrett376
garrett376's Avatar
Don't know if the C4 is different than the C2 (workshop manual doesn't hint at this) - but there is no ABS menu on the Hammer specifically. I have DME ( watch all the engine stuff going on - that's fun), PDAS, Heater, Airbag, and Alarm. You'd need something called an ABS 2-LED tester to diagnose problems with that system. The Hammer does not appear to do anything with the ABS system unless a fault code is registered, which shows up under the PDAS system (on a C4) - I am not sure if it would show up at all for a C2. On my C4, the ABS speed sensors will show faults, as would the acceleration sensors but these show up in the PDAS menu - maybe there is an ABS menu instead of a PDAS menu on C2's?
It is my understanding that the fluid in the brake system runs through the ABS block - when you bleed your brakes, you are pulling the fluid through the ABS system. I think that's how it works - but of course, I could be wrong!
Old 05-22-2004, 12:06 AM
springer3
springer3's Avatar
The menu system lists "ABS" on the C2. My guess is that the PDAS includes all the elements of the ABS, and therefore does not need to be listed separately.
Old 05-22-2004, 06:55 AM
John Speake
John Speake's Avatar
You are correct Paul. PDAS includes ABS.
Old 05-22-2004, 10:32 AM
joey bagadonuts
joey bagadonuts's Avatar
Nice work, Garrett! Thanks for posting.
Quick Reply: bleeding the PDAS using the Hammer... - piece of cake!
