964 Forum 1989-1994
C2 incoming
Old Mar 23, 2023 | 05:39 PM
  #61
LionelB's Avatar
LionelB
Originally Posted by rsabeebe
can you give some feedback on the 100 cell cat? manufacturer and vendor?
Here it is:
https://scart.com
Old Mar 23, 2023 | 05:41 PM
  #62
LionelB's Avatar
LionelB
Originally Posted by Peteinjp
The thing about the brembo smaller rotors (332) for the front is that the piston sizes match the original sizes for the 964 so the master and booster can stay stock. That helps offset the cost a bit.
Pete
Interesting. I have not looked at that option. I have not pulled the trigger on brakes yet.
Old Mar 30, 2023 | 07:51 PM
  #63
LionelB's Avatar
LionelB
Things are moving along
Old Mar 30, 2023 | 10:11 PM
  #64
Bxstr's Avatar
Bxstr
Enjoying watching the progress.
Old Mar 31, 2023 | 11:56 AM
  #65
rsabeebe's Avatar
rsabeebe
Originally Posted by LionelB
Here it is:
https://scart.com
thanks!
a bit hard to justify that price - and i spend car money quite easily!!
Old Mar 31, 2023 | 01:05 PM
  #66
LionelB's Avatar
LionelB
thanks!
Let's say that given the price of the full rebuild it felt almost reasonable
Old Apr 3, 2023 | 01:04 PM
  #67
LionelB's Avatar
LionelB
Trying to put the brake order in and my head is about to explode
So using the BBi uprights,
I would like to use drilled rotors front and back in RS size so 322x32 front and 299x24 rear.
Next on the calipers can I use standard 964 RS calipers front and back ?
So many threads on the topic that I am getting confused
Old Apr 3, 2023 | 03:56 PM
  #68
LionelB's Avatar
LionelB
Trying to answer my own question after re-reading 10 threads, this is easy to mess up that order it seems.... I think it goes like this:
993Turbo front rotors (and not the 964RS rotors because of the BBi Carrier)
964RS rear rotors
964RS front calipers (these bolt right into the BBi with no adaptors right ?)
964RS rear calipers
Assuming the above is right, I see a lot of people went to 993 Master cylinder+Booster by why not go to the 964RS MC and booster that is bigger ?
Old Apr 3, 2023 | 06:05 PM
  #69
Tomfun's Avatar
Tomfun
964RS uses electro-hydraulic booster like a C4, but your C2 uses vacuum boost - I think the 993 MC+Booster is considerably easier to integrate with a C2.
Tom
Old Apr 10, 2023 | 01:21 PM
  #70
LionelB's Avatar
LionelB
Getting there
[img]https://i.imgur.com/RxWMYOL.jpg
Old Apr 10, 2023 | 01:27 PM
  #71
rsabeebe's Avatar
rsabeebe
i hear ya and i fully understand.
Old Apr 13, 2023 | 09:42 AM
  #72
LionelB's Avatar
LionelB
This arrived and I pulled the trigger on the brakes and MC.... Thanks to Bill for "validating" that everything will work together as this is not that straightforward.
Old May 9, 2023 | 11:02 AM
  #73
LionelB's Avatar
LionelB
Paint is done
Old May 17, 2023 | 08:50 AM
  #74
LionelB's Avatar
LionelB
These showed up, re-building starting today.
Old May 17, 2023 | 11:19 AM
  #75
das76's Avatar
das76
Great choice! I’ve got the same ones. Haha. They are incredible at night.
