964 Forum 1989-1994
Yet another "I'm going to refresh the A/C" thread.
Old Jul 2, 2022 | 01:56 AM
  #31
nirich's Avatar
nirich
Once all the servos have been removed, remove the expansion valve and the pipe support behind it.
Old Jul 2, 2022 | 01:58 AM
  #32
nirich's Avatar
nirich
Carefully pry off all the clips around the two suitcase halves, undo the 6 screws marked in red (3 of mine where rusted in place and 2 required drilling out) and from there it should all come apart. The right and left mixer flap rods can be easily poked through the top section of the suitcase.
Old Jul 2, 2022 | 02:02 AM
  #33
nirich's Avatar
nirich
The flap has a metal plate with foam. When the flap is horizontal it is supposed to seal off incoming heat. However, when fully open (vertical) they do not seal. There is a gap of about 15 mm and there is no way a number 2 or 4 servo can close that. Presumably it is designed that way.
Old Jul 2, 2022 | 02:17 AM
  #34
racoguy's Avatar
racoguy
I drilled those flaps apart and put new foam on them and riveted back together.
for the foam on the main flap and side flaps I used headliner material. It's foam backed with a woven layer.
Old Jul 2, 2022 | 02:20 AM
  #35
racoguy's Avatar
racoguy
3 screws were rusty on my box, broke the heads off to get them apart. A little heat on the plastic and sharp small cutter pliers did the job getting the remaining rusty screw remnants out.
Old Jul 2, 2022 | 06:20 AM
  #36
nirich's Avatar
nirich
That's what I thought I would do to.........drill out the rivets etc. Good idea with the headliner, I was going to go with 3mm or 4mm neoprene.
Old Jul 2, 2022 | 06:21 AM
  #37
nirich's Avatar
nirich
Same damn problem screws. Must be some water sits in the hollows.
Old Jul 2, 2022 | 06:33 AM
  #38
racoguy's Avatar
racoguy
Neoprene I don't feel has enough give. I've used headliner material for years and on dozens of cars, has always worked great.
Old Jul 2, 2022 | 08:32 AM
  #39
0luke1's Avatar
0luke1
From: South Florida and Jersey shore (Monmouth County,)
https://www.classicretrofit.com/en-u...ic-964-and-993
Old Jul 2, 2022 | 09:53 PM
  #40
Metal Guru's Avatar
Metal Guru
I was able to slip the foam under into the gap without disassembly. There are barbs to hold it in place.
Nick, since you're in this deep, did you consider getting all the hosing changed to barrier hose? That way you can have fresh hosing that will allow you to charge your system every 5-7 years. R-134a that's up to pressure and quantity has more thermal capacity the R-12.
Old Jul 2, 2022 | 11:57 PM
  #41
John McM's Avatar
John McM
25 Year Member
Nick, good pics. Not that I would expect any less from you. John and I sourced new compressors from Rock Auto. About NZD 400 landed. You are going this far, it would be a shame to leave a 30 year old weak link in the system.
Old Jul 3, 2022 | 04:59 AM
  #42
nirich's Avatar
nirich
Yup. All things going to plan the hoses will of the barrier type.
Old Jul 3, 2022 | 05:04 AM
  #43
nirich's Avatar
nirich
My compressor did check out fine. But I did intend to replace it anyway as one has no idea how long those old bearings will last. I do NOT want to have to revisit this again. Rock Auto always have brilliant pricing.
And of course 'while I'm in there' the fuel tank filter will be changed, tank cleaned out, new fuel pump and hoses.
I forgot to mention that two new blowers are going in as well.
Old Jul 3, 2022 | 05:07 AM
  #44
nirich's Avatar
nirich
One of the flaps dismantled along with its cover. I was going to remove the foam around the flap and use it a s a template. No such luck.......it went from zero to dust in 0.5 seconds!
I will take Racoguys advice and find some car headliner material for this, in the meantime I will be busy cleaning 'stuff'.
This part butts up to the car body. You can clearly see the screw hole in the center and the two studs for the nuts that need to be undone in post #19.
Old Jul 3, 2022 | 06:50 AM
  #45
racoguy's Avatar
racoguy
I have tons of headliner material if you're in Auckland. Free.
I did my write up on my thread today but looks like you've got most of it sussed.
