964 narrow body rims
I have the Speedline 3.6 wheels on my car, with stock suspension. They fit, but there is a little bit of rub with aggressive driving.
Sizes: front 8x18, ET 52
Rear 8x10, ET 61 w/ 5 mm spacers.
So if your wheels have 50 mm ET front and rear, they should fit with no spacers.
3rd Gear
what wheel spec did you use?
I have various wheels with differing offsets, no spacers used and no arch rubbing, just a little kiss on the tub when parking on full steering lock.
Currently running Work Brombacher with the following spec.
Front 8.5x18 et 54
Rear 10x18 et 47
Tyre sizes or if you're in the US, Tire sizes, to use are;
Front 225x40x18
Rear 265x35x18
Some people opt for 215 front and 255 rears...
Fitment and rubbing all depends on your geometry, Camber, Caster, Toe etc..
With aggressive camber wider wheels can be made to fit without rubbing.
My geo is set at 964 RS specs.
3rd Gear
They should fit no problems.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Front 8.5x18 et 54
Rear 10x18 et 47
Front 225x40x18
Rear 265x35x18
Front 8.5x18 et 54
Rear 10x18 et 47
Front 225x40x18
Rear 265x35x18
Well, the real Speedlines are heavy. Like 24-28 pounds per wheel IIRC. They are cast aluminum centers. The RH replicas are also cast aluminum. You're not running Speedlines for track levels of performance so much as aesthetics.
