Since I got the car I could not get any radio stationed tuned in and while cleaning the car today I found this box that seems to convert the cars Antenna to a type that the Continental radio can use.
The box has a wire that looks like it may have been connected somewhere at some point.
Now I read that there is amplifier for the windscreen antenna. The Porsches antenna cable has a wire coming from it and that seems to be wired to the stereo.
So my question is, should that wire coming from the small box be powered?
This is probaly a FM antenna amplifier, fitted by an installer with little or no knowledge of this type of vehicle. I see no need for it, since the 964 already has an antenna amplifier, placed under the windscreen in the frunk.
Using two amps will probably only introduce extra noise or other problems.
The original antenna amplifier indeed needs a power supply, connected to the apprpriate output on the head unit. This power supply is the thin (most often white) wire bundled along the coaxial cable.
The original coax connector plugs directly into the Conti, just pull out the adapter first.
Cheers,
Tore
Cheers,
Tore
Hey Tore,
Big thanks for your reply and I will check to see if there is power on the Porsche Antenna side as I can see that cable joining to another thin wire as well that I presume goes to the Conti radio.
I wonder did someone connect that box/ amplifier as well and I pulled that out when I had my head under the dash.
Maybe I can find just a converter cable with no amplifier in it.
It looks as though in the picture the unit can be bypassed. You should be able to remove the plug from the factory amp that is plugged into the aftermarket amp and plug it directly into the radio input. The factory antenna amp is located in the upper right hand side under the dash. The antenna connects to the amp via a special connection from the windscreen. These connections can get damaged and if pulled away can break free from the windshield. I would check all of these as well. The antenna amp has its own fuse in the fusebox AFAIK.
