Taillight question
Does anyone have a picture of what the taillight cavity looks like with the light removed? I'm wondering if I the LED drivers could be placed in that cavity or perhaps inside the engine compartment if there is a conduit.
Thanks in advance!
https://www.bergvillfx.com/products/...led-kit-us-red
Ill have to look to see if I have a picture with the center reflector removed, but heres the two corner lamps removed:
Left rear corner
Right rear corner
I’ll have to look to see if I have a picture with the center reflector removed, but here’s the two corner lamps removed:
Left rear corner
Right rear corner
I'm doing something a bit more involved, with LED halo strips. Similar to this thread: https://rennlist.com/forums/996-foru...aillights.html
Planning on doing an LED continuous outline of the entire taillight, in three intensities: running, brake and blink.
Looks like there may be room for the drivers against the back of the cavity. They are roughly 2.5"x1.5"x1" and there's two per side.
If not I'd have to snake wires through that grommet and place them behind the cavity. Do those wires lead to the engine compartment, or is that area inside the rear fender well?
also, what on earth are those white hoses for??
Sounds like a cool project, good luck! I'll be curious to see what you come up with.
I'm not entirely certain where the wiring harness goes as the PET isn't exactly clear, but from visual inspection I don't think they run through the engine compartment.
If you're looking for space for the drivers, you might have more luck behind the center reflector. Here's an image from a thread about a rear reflector substitution panel that shows whats behind the reflector.
Thanks, this is super helpful! Installing a continuous red halo strip across both taillights AND the center reflector is another project I've been meaning to investigate. This picture helps a lot. There is much more room behind the 964 reflector than there is behind a 996 C4S!!!
