Winter work advice
#46
Well this is annoying.... the car hasn't run since I refitted and checked all the injectors, waiting for Spring as usual. Done an oil change and hydraulic bleed, started it up, and have a misfire on idle.
I've checked the usual suspects - vacuum lines, electrics, but seems odd that it would occur now.
Suggestions on where to check next? Spark plugs, distributor? (I only changed the belt last year).
#47
I had ALL my injectors seize after I had them cleaned but did not immediately run them. Probably waited ~2mos while I finished my engine build. Sent them back for a re-cleaning and all good since.
#48
I did run the car immediately after fitting the cleaned injectors back in December, and it ran really well. Since then it's not been run for almost 3 months.
