Computer control unit
Hi folks, I’m trying to locate the connections for the control unit pictured. It’s located under the dash. Two connections are fine and appear to go into the door. The third (coloured red black brown) I can’t see the mate for.
it’s a 1991 964 C4.
At the top of the pic you can see the connections I’ve located.
can any soul send a pic of this connected up please?
Thank you
it’s a 1991 964 C4.
Thank you
This does not look like a Porsche part, but an aftermarket unit of some kind. Maybe an alarm unit?
Any Porsche information on the label? If not, it is most probably not a Porsche part.
Cheers,
Tore
Cheers,
Tore
I don’t see much on google and no vw item. Just the below. You’re right it isn’t in the PET. But it certainly helps if it looks like something you’ve ditched before. I’ll trace the lines into the door. Thanks for the help guys.
I did a translate from German to English komputer obviously computer the other came back Polish for stero controller I wonder if your car had at one time the CD changer mounted in the frunk
it is a mystery to me right now
